Alternate thread title......How far into my finger can I shove a metal pick?
So I'm learning to clean bearings. Managed to get the clip out of one side of a metal sealed bearing, but can't seem to get the other. Having visions of shoving an exacto blade or a one of my small picks deep into a finger.
Just venting really, but since I'm here I'll ask. Can you clean a bearing effectively with just one side opened up?
Thanks.
Removing circlips from bearings...a small rant.
- Has thanked: 727 times
- Been thanked: 26 times
Re: Removing circlips from bearings...a small rant.
Hi,
With metal shielded bearings you don't have to remove the shields, there is a very small gap/clearance
between the shield and the inner race.
This is what I use a RPM bearing blaster, I use a cheap WD spray for cleaning and a light weight oil for
lubrication, just lay the bearing on its side and put a couple of drops of oil on it and let it soak into the
bearing or I have used a pressure pack oil (bicycle chain lube) and used the bearing blaster to oil the
bearing.
http://www.rpmrcproducts.com/products/tools/fixtools.htm
Cheers, Dave.
bearing.
Cheers, Dave.
- Halgar
- Has thanked: 146 times
- Been thanked: 197 times
I would agree about not removing side shields to clean bearings. If a bearing is crunchy, it needs to be replaced anyway. For the light cleaning that most brgs need, the above suggestion is the way to go.
- 2694 Views
Last post by juicedcoupe
- 29 Replies
- 3059 Views
Last post by seth556
- 1092 Views
Last post by RichieRich
- 1585 Views
Last post by mikea96
- 565 Views
Last post by Frogwagon
- 76 Replies
- 9972 Views
Last post by TerryC
- 1291 Views
- 1553 Views
Last post by rraeford
