JRXT JRX PRO chassis differences?
- bully
- Been thanked: 6 times
I am sure i read it here b4 but can't find it now, as the title says are the chassis the same between the two? I noticed tbg are doing jrx pro undertrays an wanna double check b4 I grab one? I assume a cutout down either side for side link mounts if needed an it should fit a jrxt? Thanks everyone
- bearrickster
Re: JRXT JRX PRO chassis differences?
the pro and T use the same chassis both can run H arms or 5 Link, the jrx2 uses a shorter chassis
- bearrickster
- highwayracer
The early jrxt chassis does not have the slot for the servo saver because the servo saver was built into the bell crank. When the Jr pro was released, it used the rigid red bell crank....so a traditional servo saver was needed.
- highwayracer
Here's some info on the different jrx chassis:
jrx2
graphite (no slot)
short wheel base
20 degree front kick
wide - can use the 5 link
jrx proformance kit
graphite (no slot)
long wheel base
30 degree front kick
jrx pro
graphite with slot
long wheel base
jrxt
graphite (no slot)
long wheel base
junior 2 / junior t
composite with top brace (no slot)
long wheel base
jrx pro SE / LXT
extra long wheel base for trucks and standard long for the buggy
narrow - cannot use the 5 link
Hope this helps...
jrx2
graphite (no slot)
short wheel base
jrx proformance kit
graphite (no slot)
long wheel base
jrx pro
graphite with slot
long wheel base
jrxt
graphite (no slot)
long wheel base
junior 2 / junior t
long wheel base
jrx pro SE / LXT
Hope this helps...
Man, there is so much great information on here!
So I have a JrxT/Jrx-Pro chassis I came across that has a strange, bumpy texture to it. No "oreo sandwich" look either- appears to be solid carbon. Is it some aftermarket plate?
Thanks all!
Thanks all!
TEAM LOSI/TRINITY
SPLAT! GRAPHICS
SPLAT! GRAPHICS
- RC10resto
- Has thanked: 1487 times
- Been thanked: 550 times
You sure it is a long chassis?
Some early JRX2's had the textured chassis'
http://www.rc10talk.com/viewtopic.php?f=27&t=20654&hilit=JRX2+textured+chassis
Ok, I double checked and found that indeed I have one normal "oreo" T chassis and one solid carbon chassis with a light texture to the bottom of it. Not as wavy and shiny as the early Jrx2 plate. Subtle variation I guess.
I did find that I have one of those early Jrx2 chassis' also! Cool! I didn't know they were rare!
Thanks for the link.
TEAM LOSI/TRINITY
SPLAT! GRAPHICS
SPLAT! GRAPHICS
Oh, and the center 2 battery holes on my texture plate are also ovaled out btw.
TEAM LOSI/TRINITY
SPLAT! GRAPHICS
SPLAT! GRAPHICS
- 1055 Views
Last post by FasterLouder
- 1850 Views
Last post by Bongo Fury
- 1665 Views
Last post by Momo5
- 2633 Views
Last post by mrlexan
- 1439 Views
Last post by bearrickster
- 26 Replies
- 4449 Views
Last post by legooolas
- 20 Replies
- 1576 Views
Last post by cas22
- 1504 Views
Last post by cas22
