Hi Guys,
I have a never run Yok Works 91, but I have the problem that I don't have the original rear wheels, wing or original tyres for it.
It looks from a lot of the pictures on here that they had the square block front tyres and a long pin type tyre in the rear.
I know hotlaps/yok tyres used to have the part numbers on the sides, so could someone please let me know the part # for the tyres?
Regarding the wheels, I have pink 2.0" rears with 4 mounting holes and pink 2.2" fronts with 2 mounting holes. Which are the correct standard wheels? I believe it is the 2.2" with 2 holes right?
And finally, does anyone have any idea on the part# for the original rear wing? AE's high downforce rear wing looks close, but isn't exactly the same.
Thanks very much,
Jim
Help With Yokomo Works '91
- carloco8
- Has thanked: 74 times
- Been thanked: 271 times
Re: Help With Yokomo Works '91
Jim, you need to get into the BST area. You will get a better response there and perhaps find just what you need
Here's how:
http://www.rc10talk.com/viewtopic.php?f=1&t=909
Here's how:
- Has thanked: 131 times
- Been thanked: 40 times
Hi Jim,
Just so you know what you are looking for when you enter the BST forum, here are the part numbers you will need-
Front Tires Works '91: TF-340M
Rear Tires Works '91: TR-38M or TR-32M (TR-38 are difficult to obtain)
Front Rims Works '91: ZC-831 Pink Design with 2 Holes
Rear Rims Works '91: ZC-837 Pink Design with 2 Holes
Rear Wing Works '91: ZC-108 (similar in design to Team Associated 6185 in case you can't locate one)
Hope this helps.
Vin
Hope this helps.
Vin
Thanks guys.
Sorry, yes I have seen the BST post, just haven't been able to sort out getting onto it yet.
Thanks very much for the part numbers Dual! I thought the tyres were 31's and 310's..Doh!
- 3632 Views
Last post by stickboy007
- 3958 Views
Last post by dinglem
- 37 Replies
- 5254 Views
Last post by Dynotech Racing
- 32 Replies
- 7140 Views
Last post by olfrjf
- 20 Replies
- 3654 Views
Last post by Sasha8066
- 20 Replies
- 3364 Views
Last post by mrlexan
- 4463 Views
Last post by fakiee
- 4617 Views
Last post by phoenix
