Worlds Car Shocks and O-rings
What are you guys doing to assemble the shock caps to the body with the O-rings. The ones that I have seem to be a little large and are just spit out of the side when twisting the cap down. I have seen shocks in the past that instead have Teflon tape to get them to seal so apparently this o-ring deal hasn't been happiness for everyone?
The recent classic kit would do the same but a little oil on the o-ring kept the friction down on the cap and kept it in place.
- Been thanked: 498 times
Re: Worlds Car Shocks and O-rings
the o-ring should be a snug fit around the threads on the body. then yes, some oil applied should provide enough slip that you can tighten without the o-ring being ejected. it's definitely not a simple task.
A dab of oil helps a bunch to keep the cap from grabbing it and twisting it out or damaging it. This is very similar to putting a little bit of oil on a new oil filter for a car.
Additionally, not have the bleeder screw on will typically help as well.
Tim Tunnermann
Team Associated Design Engineer
Team Associated | |Reedy | XP Digital | JConcepts | Futaba | Makita | Kicker | LiveRC
First make sure your not using the slightly larger adjusting collar o-rings, they are a bit bigger, I caught myself the first time doing just that.
My O-rings for the shock tops seem too tight and were a pain to put on when my hands had oil all over them, they did seal fine how ever.
Lynn
Lynn
Hi - Are you saying that the larger of the two orings goes in the adjusting collar and the smaller goes up top with the Cap? If so.. are you sure? Thanks
- slotcarrod
- Been thanked: 45 times
100% sure!
Rod Littau
Okey Dokey.. I will get with the program then and make this work.. Thanks Guys!
Guys - Thanks for the help.
We were down in Hallett Oklahoma running the Porsche so I was working on these in the motel room and had left the instruction manual at home.
I bought new O-rings in case I nicked the one trying to install them in the wrong places. The shocks are now together correctly.
- 1592 Views
Last post by linhof4
- 1946 Views
Last post by XLR8
- 1695 Views
Last post by Synergy
- 3186 Views
Last post by bully
- 790 Views
Last post by juicedcoupe
- 3373 Views
- 914 Views
Last post by K-TOWN-KITT
- 947 Views
Last post by Disco2006
Users browsing this forum: Ty89m and 5 guests
