ESC placement
General info, Q&A.
DMAT
ESC placement
Post by DMAT »
building a car on the graphite chassis. The new ESC I have is wider than the chassis space left and I'm not sure on where to mount it, I'm considering up front next to the servo. I'm thinking it might better the balance of the car too with less weight towards the rear. no matter where its mounted, the bottom will not be fully supported.
Im trying to put a driver figure in this car so prefer to keep it low in the car.
Has thanked: 1080 times
Been thanked: 3729 times
Re: ESC placement
With a driver it's a little harder. We always ran the shock tower or used a battery cup to make a shelf above the battery
bully
Been thanked: 6 times
Re: ESC placement
Post by bully »
For my runner graphite i put esc on the side an used an undertray to give some extra side impact protection...
THUNDERSTRIKE1
Re: ESC placement
Post by THUNDERSTRIKE1 »
MOUNT IT ON ITS SIDE,takes up less room. :lol: don
DMAT
Re: ESC placement
Post by DMAT »
THUNDERSTRIKE1 wrote:MOUNT IT ON ITS SIDE,takes up less room. :lol: don
You know, that might actually be doable. I'll have to look into it.
THUNDERSTRIKE1
Re: ESC placement
But not if body sits really low.Ive seen some mount them so heat sinks stick out the body for that racer look.don
DMAT
Re: ESC placement
Post by DMAT »
I thought you mean mount the heatsink on its side. :lol:
I dont see any idea why I shouldnt try at least.
DMAT
Re: ESC placement
Post by DMAT »
Well, looks like nothing works. even with the esc sitting on the chassis, the wiires are in the way of the body sitting flat.
looks like I wont be able to use the driver either way now. I butchered the hell out of it too trying to make it sit better with the body :/
THUNDERSTRIKE1
Re: ESC placement
HOW ABOUT THE SMALLER hard plastic tamiya driver figures.Bet theyd work,don
harvey
Re: ESC placement
Post by harvey »
The new shorty pack set up with the esc behind is a pretty slick way to go...
