Magnum Sport FP-T2PB Battery Polarity
tishatang
Post by tishatang »
My son lost the battery holder for his Magnum Sport some years ago. His car car is a basket case. I want to power it up and see if transmitter and receiver work. I thought I would use variable low voltage power supply and hook to the contacts inside the pistol grip. But I don't know the polarity of each pin.
Hoping somebody out there would have an old battery holder that shows the polarity of the pins. I am sure with my luck I would hook it up backwards and blow something if I took a guess.
Many thanks,
Chris
Been thanked: 3919 times
Re: Magnum Sport FP-T2PB Battery Polarity
Looks like the lowest hanging tab is going to the spring side, so that's your negative.
tishatang
Post by tishatang »
Thanks gomachv,
If I understand you correctly, when this battery holder is installed, the pin nearest to my body is negative. And, the one fartherst away is positive?
That's how I see it :mrgreen: just going by the pic
tishatang
Post by tishatang »
OK, thanks
Users browsing this forum: No User AvatarTbot [Bot] and 4 guests
