Associated powdercoated chassis colors
I know there was blue green and pink was that it or were there others? I am building a vintage racer out of a stealth drilled a pan using new rpm arms and rere parts to essentially make it brand new and want to have a chasis powdercoated and was curious of all the colors... I have a pretty nice purple body on the car now and was thinking green but maybe if there was another color avaliable back then that trips my fancy i might reconsider the green also any tips on preping for powder coat? Strip the anno? Glass bead?
You Tell E'm Im Comin! And Hells Comin With Me
- Has thanked: 36 times
- Been thanked: 1318 times
Re: Associated powdercoated chassis colors
scr8p wrote:red, pink, blue, yellow, and green
:/ hmmm green it is i guess lol i guess on an unrelated note i am going to mill the chassis like a worlds one and i guess use rere worlds towers do you know if the rere ones are the same as the originals and use .71's front and 1.32 rear i know the rere worlds has .89's on the front did they make the tower longer or just add more droop to the car?
- Has thanked: 1129 times
- Been thanked: 3919 times
.89's are a misprint, the towers should be dimensionally the same
- Has thanked: 659 times
- Been thanked: 878 times
Not sure about the material but they look the same and the re-re actually uses .71 fronts as there was a typo in the manual I believe.
Ok cool i am just trying to build something that handels good enought to drive it around the track my gold pan with 1 hole front tower .56's and long arms handels terrable! And my graphite with 4 hole tower .71's and long arms aint much if any better lol i am building thing car to be a vintage class racer so i would like it to handel decent as my woin has been outlawed in the vintage class lol
After searching around, the pattern I'm seeing is the green and pink are the two popular colors and red and yellow are the 2nd popular, and the blue I saw, I couldn't tell if it was a nice anodizing or a dark powder coating.
Is that the trend or am I missing something?
They are all florescent colors, correct?
Were the motor/transmission plate included with the powder coated pan and nose plate?
And I assume that it was also powder coated the same color.
Every body needs reverse polarity
Yes, they're fluorescent.
Motor plates were not powder coated.
- 37 Replies
- 6896 Views
Last post by JosephS
- 1051 Views
- 1942 Views
Last post by LTO_Dave
- 20 Replies
- 3371 Views
Last post by lexus-5
- 1295 Views
Last post by 59burst
- 2917 Views
Last post by Beatnik
- 662 Views
Last post by highwayracer
- 1118 Views
Last post by AnonymousRC10
