RC10 HOT TRICK REAR TOWER CHOICES?
- Been thanked: 4 times
I JUST received in the mail a late edinger THAT HAS A FRONT HOT TRICK TOWER and HOT TRICK BELL CRANKS.dID THEY MAKE A HOT TRICK VERSion of the stock rear tower or were they all weird like ive seen.Would like one same as stock if were made to go one my real racing tube frame.DON
- Phin
- Has thanked: 87 times
- Been thanked: 248 times
Re: RC10 HOT TRICK REAR TOWER CHOICES?
Three maybe four designs of the RC10 rear tower and along with the red fiberglass they made at least one version in Carbon Fiber....but none that looked just like stock.
The buggy towers that had the triangle cut outs came with either a single shock mounting hole on each side or two holes (one upper and one lower) that was used to mount the top shock bracket for their trailing arm kit. There may also have been a rear tower that had the "touch of class" motor wire holder built in but I can't remember for sure.
There was also an oval RC10 tower that was both a front and rear shock tower.
Theirs only the motor wire holder two hole tower on ebay now.Ive had the ugly oval towers before but guess need to find the single hole tower or find red fiberglass and make my own.DON
- Phin
Could dye a stock tower red but the Hot Trick "tri-directional" fiberglass had a matte finish on it that the G10 from McMaster doesn't have. Maybe email Lohas and see if he can cut you one.
- 31 Replies
- 3825 Views
Last post by mikedealer
- 2599 Views
Last post by vintage88
- 1911 Views
Last post by orangemazda
- 1587 Views
Last post by Dr. Robotnik
- 21 Replies
- 3926 Views
Last post by RC10resto
- 48 Replies
- 7590 Views
- 3741 Views
Last post by knucklebuster
- 24 Replies
- 3490 Views
Last post by MelvinsArmy
Users browsing this forum: Semrush [Bot] and 12 guests
