Big bores on an rpm rc10 worlds clone help
General info, Q&A.
glastornjet73
Post by glastornjet73 »
Supose a guy was wanting to put big bores on an rpm worlds car which ones might he use? They went and made them metric and im not sure about lengths... I know typically the 1.32 stock shock is rather long to begin with so should i just use the t4/sc10 length ones front and rear and stay with the lengths it had or use b4 length ones or a combination thereof? Im just kicking the idea around and was kinda unsure on what ones i would beed to use? Thanks in advance dj
You Tell E'm Im Comin! And Hells Comin With Me
Y'ernat Al
Has thanked: 7 times
Been thanked: 17 times
Re: Big bores on an rpm rc10 worlds clone help
Post by Y'ernat Al »
- Brian -
My Gallery
JK Racing
Has thanked: 139 times
Been thanked: 246 times
Post by JK Racing »
If you plan on running long front shocks, T4.2/SC10.2 fronts, B4.2 rears are your best bet. On my build linked above (thank you :) ), I have B4.2 shocks all around, but I am running a CE front end, not the RPM one. You CAN run the B4.2 fronts on the RPM, just use the slightly lower mounting holes.
