Recommendation on a good cheap ESC for RC10T project
Hey all,
I'm trying to get an RC10T4 running from a bunch of parts I got in a garage sale. Before I spend a bunch of money on a brushless setup, gears, diff upgrade, CVDs etc. I just want to get it running. Unfortunately while trying to setup the throttle controls on the Novak XRS that came with this stuff, I pushed too hard on the Set button and mashed it down (or the spring failed). Of course this was after I finished expertly soldering all new connectors and cleaning up all the wiring and mounting the ESC!
Anyway, can someone recommend a cheap and widely available ESC that will work with the collection of 15T and up brushed motors I received with this truck? I'm completely new to this hobby, so learning as I go. I have a "HPI SC-15" that also came with this pile of parts, but I don't see a set button on it, and not sure if its worth the trouble to solder up a new set of connectors, etc.
Thanks in advance for your help!
RC10T4.1 Castle Sidewinder SCT & 3800kv 1410
RC18T bone stock
Slash 2WD (brushed)
Rustler VXL - more RPM & Aluminum than stock parts
Stampede 2WD XL5
XTM X-celerator (project)
RC18T bone stock
Slash 2WD (brushed)
Stampede 2WD XL5
- Lonestar
- Has thanked: 623 times
- Been thanked: 171 times
Re: Recommendation on a good cheap ESC for RC10T project
oldschool? novak M5
new school? pretty much any recent novak/LRP/KO speedo...
- teman
- Been thanked: 6 times
If the HPI doesn't have the on/off switch you won't be able to program it. The set-up button is on the on/off switch.
I'd say Novak Rooster or Super Rooster, it's my favorite brushed ESC
-Kevin
- Been thanked: 325 times
You said "brushless" in your last sentence, and you want economical...I'd suggest you pick up an EZRun or Leopard ESC for unsensored BL motors. 30A or 60A should be more than sufficient, and those ESCs are cheap.
I'm using this one in a modded Optima Mid project, it's quiet and drives really smooth. (I got it with the 12T motor & programming card combo, though.)
http://www.ebay.ca/itm/Leopard-TORO-60A-V2-ESC-Speed-Controller-Sensorless-Brushless-Motor-RC-Car-/161186605308?pt=Radio_Control_Parts_Accessories&hash=item25877868fc
- JPAE07
Associated has cheap speed controls (LRP) available on their web site. See the web specials link on their site.
Oops! Meant brushed. SorryCoelacanth wrote:You said "brushless" in your last sentence, and you want economical...I'd suggest you pick up an EZRun or Leopard ESC for unsensored BL motors. 30A or 60A should be more than sufficient, and those ESCs are cheap.
RC18T bone stock
Slash 2WD (brushed)
Stampede 2WD XL5
RC18T bone stock
Slash 2WD (brushed)
Stampede 2WD XL5
AS JPEA said checked Associated website,
http://www.teamassociated.com/parts/details/LRP80800/ this will handle any brushed motor that should be good in that truck.
http://www.teamassociated.com/parts/details/LRP83710/ 15t is the max this one can take
or check ebay, you can find a brushless set up from speed passion motor and ESC
http://www.ebay.com/itm/Speed-Passion-Reventon-S-Brushless-ESC-Metal-B-Program-Box-V3-0S-3500KV-Motor-/131089643850?pt=Radio_Control_Parts_Accessories&hash=item1e858d394a the brushless be more efficient means longer run times, less maintanance on motor.
- 1019 Views
Last post by knucklebuster
- 1539 Views
Last post by roor
- 19 Replies
- 2487 Views
Last post by purpletimbo
- 999 Views
- 960 Views
Last post by knixdad
- 2532 Views
Last post by juicedcoupe
- 1804 Views
Last post by mikea96
- 1458 Views
Last post by Group B
