yz10 rod ends
brian s
yz10 rod ends
Post by brian s »
does anyone know where i can source some new white plastic/nylon rod ends ( zc402) from, or an alternative that will fit.
Been thanked: 3919 times
Re: yz10 rod ends
In the wanted section?
Re: yz10 rod ends
Traxxas rod ends fit on the yokomo balls if you have the balls, or just use the traxxas balls. RPM makes white ones but you need a beefy turnbuckle like 3.5mm or maybe even 4mm.
DennisM
Has thanked: 30 times
Been thanked: 62 times
Re: yz10 rod ends
Post by DennisM »
These are possibly the most wanted Yokomo parts, so unless You´re one heck of a charmer or just loaded with cash, it´s going to be long quest :mrgreen: My advice is to buy a good condition YR4 and use that as a donor.
Gone fishing
Re: yz10 rod ends
I picked up a yr4 nitro just for the bits, it went for $15 on eBay. These things pop up once in a while, I've paid a whole lot more for a bag of parts than I have for a complete car a few times.
Re: yz10 rod ends
you can also 'fake' it by using the associated shock ends and balls also.
aip47-2008
Has thanked: 170 times
Been thanked: 23 times
Re: yz10 rod ends
Post by aip47-2008 »
DennisM wrote:These are possibly the most wanted Yokomo parts, so unless You´re one heck of a charmer or just loaded with cash, it´s going to be long quest :mrgreen: My advice is to buy a good condition YR4 and use that as a donor.
x2
Has thanked: 358 times
Been thanked: 470 times
Re: yz10 rod ends
hmmmmmm I just sent someone 2 NIP packs :oops:
DennisM
Re: yz10 rod ends
Post by DennisM »
Charlie don't surf wrote:hmmmmmm I just sent someone 2 NIP packs :oops:
Tsk tsk, You´re just so easy to charm :D
Gone fishing
Re: yz10 rod ends
:lol: It was a buddy....Just don't recall which one :lol:
I really didn't know that they were that rare, not that it would have mattered
Re: yz10 rod ends
Guess I need to "stock up".
:twisted:
Justjoe
Re: yz10 rod ends
Post by Justjoe »
The YR4 rod end part number you want is ZR-007. if youre talkin suspension
USAF Retired
870C, Works 91, YR4-M2 Pro, RC10 Graphite, RC10 Carbon fiber tub
Old Skool RC10 Gold pan, RC10DS, Traxxas REVO
brian s
Re: yz10 rod ends
Post by brian s »
i suppose that these are as rare as hens teeth as are most works 91 parts
brian s
Re: yz10 rod ends
Post by brian s »
anyone know if the Yokomo MX4 ZM-400 rod ends are the same size
Alex B
Has thanked: 23 times
Been thanked: 46 times
Re: yz10 rod ends
Post by Alex B »
brian s wrote:anyone know if the Yokomo MX4 ZM-400 rod ends are the same size
Yes
http://www.end-of-line-rc.com/cars/option-parts/yokomo/mx4/mx4-upper-iarm-set.html
Comes with balls and rod ends and turnbuckles, although they are the wrong length for a YZ 10.
:shock:
Return to “Yokomo Forum”
