RC12i Help
retrorobot
RC12i Help
Post by retrorobot »
I want to purchase this car from a seller but not 100% sure its a RC12i original. Was the Rc12i kit ever release in "Black Fiberglass"?
I am not sure if they car has anything missing, or modified from what the original should be. Maybe you guys can tell me?
Looking from the pics he sent me I Notice the rear body mounts is missing, and area where it would have mounted on the top plate look like that part of fiber glass been removed? Can anybody confirm if such a top plate exist or was the top plate moded?
Also I notice the front Battery post are missing. There is a white servo mount? I thought the Rc12 never had servo mounts? Is this a mod, or does it exist in the black fiberglass version?
Does this car have a ball differential or not? Because he could have used the RC12e shaft?
If you guys notice anything else let me know? Do you guys think its worth it to buy it and how much? I don't want to have to spend extra to fix this thing either
thanks
Has thanked: 1075 times
Been thanked: 3680 times
Re: RC12i Help
Early 12i, chassis was likely dyed black. The early had no front springs instead using chassis flex. Also no front posts on early cars. Upper radio tray is trimmed of its body mount tabs, they broke a lot. Ball diff was standard, likely a hollow steel axle where the later had graphite. Servo mounts are not stock, battery straps and the metal attachments are stolen from a kyosho
Factory Works website
ChisaiKuso
Has thanked: 5 times
Been thanked: 27 times
Re: RC12i Help
Post by ChisaiKuso »
I think gomachv pretty well covered what you are looking at. :wink:
Something clever goes here...
retrorobot
Re: RC12i Help
gomachv wrote:Early 12i, chassis was likely dyed black. The early had no front springs instead using chassis flex. Also no front posts on early cars. Upper radio tray is trimmed of its body mount tabs, they broke a lot. Ball diff was standard, likely a hollow steel axle where the later had graphite. Servo mounts are not stock, battery straps and the metal attachments are stolen from a kyosho
The steel axle is hollow? So it's more like a pipe then?
Would it be possible they had black fiberglass back in the day, or possible aftermarket back then. Dying rc parts is relatively a new trend right? This car look like it wasn't used for like several decades. Kent Clausen world champion car had some black fiberglass parts on it
Re: RC12i Help
Anything is possible but dying isn't new era. It was more likely dyed but without seeing good pics of it, hard to say. His steering blocks were dyed as well
The early axles that were steel on the 12i were hollow from my experiences. There may be solid ones but I haven't run across any. If there is no diff, it was either swapped in or it was from a club racer version that I have seen mention of in the instructions but never seen one pop up
retrorobot
Re: RC12i Help
gomachv wrote:Anything is possible but dying isn't new era. It was more likely dyed but without seeing good pics of it, hard to say. His steering blocks were dyed as well
Do you think it even worth if if i offered him $30 as roller and its local pick up. Given the fact it missing body post and battery and top plate might need to replace or fixed is it worth it?
Or better getting one on ebay? I seen them some go for around $40-50 on ebay but then i have would have to pay $20 shipping and possible customs
But i guess with local pick up i can inspect it.
Re: RC12i Help
It looks like it would be worth $30 the way it sits, especially as a runner
clinehobbies
Re: RC12i Help
Post by clinehobbies »
The motor in it is prob worth more than the car :)
Have a nice day! :)
retrorobot
Re: RC12i Help
clinehobbies wrote:The motor in it is prob worth more than the car :)
How much is the motor worth?
retrorobot
Re: RC12i Help
gomachv wrote:It looks like it would be worth $30 the way it sits, especially as a runner
$30 just for the roller but it does include the motor. still worth it?
Re: RC12i Help
I mean a runner in the sense that you plan to run it. It probably wouldn't be a great car to restore, but as a runner it looks great
klavy69
Moderator
Has thanked: 624 times
Been thanked: 294 times
Re: RC12i Help
Post by klavy69 »
pretty much got your answer but here is the bible on values for these on this board :wink:
Re: RC12i Help
How do i always get tricked on these valuations :lol:
retrorobot
Re: RC12i Help
klavy69 wrote:pretty much got your answer but here is the bible on values for these on this board :wink:
Haha i didn't know there was a rule for this, but good to know
