Tire Recommendations? (10T and T3)
natob2
Post by natob2 »
I am considering getting new tires for my recently restored 10T and an upcoming restoration of a T3.
The use for both trucks will be multipurpose, no racing. I'll be running on the streets and in the backyard which is a mix of grass and a lot of pine needles.
The 10T is a brushed setup. The T3 will be brushless. Any recommendations would be greatly appreciated. Thanks!
clm
Has thanked: 100 times
Been thanked: 205 times
Re: Tire Recommendations? (10T and T3)
Post by clm »
For something like that you should look into multi surface tires like pro-line dirt hawgs.
Chris
Mini - T, LST, LST2, Crawler
Micro - Trekker, SCT, T
Sixtysixdeuce
Post by Sixtysixdeuce »
Got some pictures?
CLM's recommendation of the Dirt Hawgs is a good one, but I actually like the Dirt Works better as a bashing tire on a 1/10 2WD:
More space between lugs, so a bit more bite in dirt & mud, and better self cleaning. But also less appropriate for paved surfaces.
Honestly, I really like Traxxas Talons, too, but you'd have to run 2.8" wheels.
Stay away from the HPI Yokohama Geolanders; They look cool and they're cheap, but pretty much a no-terrain.
If you're ever going to see hard pack and/or clay, though, I'd suggest Proline Calibers or JConcepts Goosebumps.
teman
Been thanked: 6 times
Post by teman »
Pro-line gladiators all around :wink:
-Kevin
natob2
Post by natob2 »
I just took my RC10T out on snow plowed streets (in 4 degrees!) with the stock wheels and wow, what a mess. It'd hit about 15-20 mph and would spin about four times. My tires are very unmatched for the snow! (or really any remotely slick surface) I took out my RC10T for the first time in 17 years (!!!) with a light dusting the other day in my backyard and it ran beautifully, but tonight was a completely different story. Realized how bad I need new tires.
Thank you so much for the recommendations. I researched them all and ended up with ProLine Gladiators. They all looked like the right tires for my use but I got the Gladiator 2s for a steal on eBay.
maruirc
Post by maruirc »
I had a set of those. No traction and wear fast. The dirt hawgs are way better and last lots longer. Good tire for multi surface.
slotcarrod
Been thanked: 45 times
Post by slotcarrod »
teman wrote:Pro-line gladiators all around :wink:
X2 :wink:
Return to “RC10 Truck Forum”
