Wrenching on the XXX-NT w/ .12Picco
Forum rules
T4EaterJonny
Post by T4EaterJonny »
So I couldn't get it going yesterday... It fired but couldn't stay running. Glow plug was brand new. I ripped off the fuel filter (clean anyway) looked in the carb and decided to clean it. When I went to put the carb back on I noticed a little small o-ring. Does this go on the engine part and gets squished by the carb as you press it down? I'm sure i have it in the right place. I'm not sure where else it would go. I felt something fall in my lap while i was working on it and I didn't see where it fell from.
Also, should the carb be able to spin around after the pinch bolt is tightened? It seems secure, but I don't feel like that's supposed to happen. I don't want to overtighten it and break something. I read somewhere that I should use RTV?
Use Permatex RTV automotive, O2 sensor safe silicone at the carb base around the O-ring and press the carb down while you tighten the pinch bolt
1 xxxnt with fantom .12
1 xxxnt with picco .12 RC speed
1 LXT with ..... not much! :-p
T4EaterJonny
Re: Wrenching on the XXX-NT w/ .12Picco
Bump.... Is the carb supposed to spin or no? I've got it pretty tight. it doesn't spin easily, but if I turn it pretty firmly it will turn. I really don't want to over tighten it and break something. I usually never let my stuff sit and let crap build up- hence never learning how to clean and take it apart lol.
Chris K
Post by Chris K »
Carb is supposed to be stationary and NOT spin.
With that said, you should probably use some RTV (sensor safe) where the carb meets the case - it doesn't take much but my guess is that it will leak since it's obviously not getting super tight. A dab around where you tighten might help a bit too.
Also, be 100% sure that the carb linkage angle is correct before you add the RTV.
Let the RTV set (overnight) and you should be good to go!
Wherever you go; there you are!
