Anyone ever build a "worlds" style buggy with a t2 chassis?
I was doing some thinking last night and am in the middle of a graphite worlds build and i though heck why couldnt a guy use a t2 chassis to build a "worlds" style buggy? You would have a 2.6 trans newer atyle pan with the higher ground clearance on the sides and litterally all you would have to so is change arms and rear axles steering bellcranks add a front mount to one of the bellcrank bolts and come up with a rear body mount and wing mount... Wouldnt be that hard to do really just a thought... Has anyone you know of tried it? Im thinking i might
You Tell E'm Im Comin! And Hells Comin With Me
- Has thanked: 36 times
- Been thanked: 1318 times
- Has thanked: 1129 times
- Been thanked: 3919 times
Re: Anyone ever build a "worlds" style buggy with a t2 chass
Did you make the shock towers?
Copied the rear and made the front. I just used a stock tower as a template and narrowed it up
That thing is awsome i guess im gonna have to pick up another t2 to do one if these out of! Did you shorten the wheelbase of yours like scr8p did? I didnt realise the pan was longer... I know there is a longer mount hole if truck form but i figured the standard holes were regular rc10 length...
I didn't shorten mine but I should have. It was sold before I ever ran it
- Has thanked: 100 times
- Been thanked: 205 times
They all look good, I have one up on the planning block myself somewhat different insired then those. It is basically going to end up a white nylon team car with t2 pan, this is the mock up pic of it before I sent out the tub to be reano'd. There is much left to get before it's done though.
Chris
Chris
Mini - T, LST, LST2, Crawler
Micro - Trekker, SCT, T
Did you redrill the pan to use the older style stealth? Or you come up with a diffrent style trans brace? My biggest thing i was thinking would be cool is the use of a more modern 2.6 ratio transmissions that the t2 had to offer
- 2927 Views
Last post by mikea96
- 27 Replies
- 2999 Views
Last post by Sixtysixdeuce
- 184 Replies
- 23757 Views
Last post by RJK33
- 34 Replies
- 4928 Views
Last post by smurf420
- 21 Replies
- 3686 Views
- 3374 Views
Last post by phoenix
- 878 Views
Last post by TokyoProf
- 1022 Views
Last post by R Cane
Users browsing this forum: DotNetDotCom.org [Bot] and 5 guests
