So I was looking around at making a custom order for a screw set. I remember a while back asking about screws in another thread because they werent fitting properly. well I finally figured it out. Older sets had a 100 degree flat head vs an 80 degree flat head. this is for the 8-32 screws. the 4-40 screws still appear to have the 80 degree head.
someone probably already found this but Thats what im seeing now. I ordered 2 different screw sets for the rc10 and both had 80 degree flat heads vs the 100 degree needed.
Flat head screws
- Has thanked: 1129 times
- Been thanked: 3919 times
Re: Flat head screws
If it's an aluminum 8-32 screw in an rc application it's almost always 100 degree unless it's metric , then it's 90. If it is steel there is a good likelihood it's 82 degree. You won't find 100 degree in black oxide easily, sometimes in stainless.
4-40 screws are all 82 degree wether aluminum or steel.
Here is one example, the losi junior series used steel screws in the upper deck, they are 82 degree and the chassis was countersunk to that. The chassis screws are 100 degree and it was countersunk to that. Different countersinks on the same car for different hardware
100 degree is considered aircraft hardware.
- 582 Views
Last post by Brandon G
- 764 Views
Last post by SMOKE-DOG
- 21 Replies
- 2619 Views
Last post by Lowgear
- 751 Views
Last post by Falsepleasure
- 2665 Views
Last post by Superathlete
- 1479 Views
Last post by bearrickster
- 986 Views
Last post by LowClassCC
- 602 Views
Last post by adam lancia
