SFC K's Re-Re build
SFC K
Has thanked: 47 times
Been thanked: 9 times
SFC K's Re-Re build
Post by SFC K »
Ok, here is my Re-Re build up.
Steering and front nose added onto the chassis. I am not liking the steering set-up so that will be swapped out soon.
Front shock tower added...
Pictures of the rear bulkhead...
And the green/translucent ball cups...They do help being this way though when you thread the threaded rod end in. You can see how far they are so you can get them even...
Shocks all built up...Some anodizing issues on top of one of the caps and inside one of the fronts.
Shocks mounted and the front nose braces mounted up...Need to order the bumper for the front that looks like a taco... :wink:
Jeff
SFC K
Re: SFC K's Re-Re build
Post by SFC K »
And the rear arms mounted up. No issues with these.
All that is left to build is the transmission, rear end spindles and axles, and the wheels. Need my bearings to show up so I can proceed further...
So far it has been fun and the manual has been vague in spots on what parts are need when. a lot of parts over all. I don't remember having to mess with so many parts on my rebuild of an old RC10. I am so glad I opened it to build it up.
Jeff
Been thanked: 3919 times
I guess that answers my question about the arms stopping on the chassis like the original kits! They do not and rely on the shock spacers. No big deal, the original stops wore down super quick anyway
SteveK
Post by SteveK »
SFC K wrote: Shocks mounted and the front nose braces mounted up...Need to order the bumper for the front that looks like a taco... :wink:
I'm going to email Team CRP and ask if they would consider selling their front bumper again. They still sell one drilled for the 10T and Losi bulkheads.
SFC K
Post by SFC K »
That would be great Steve! :D
Jeff
lexus-5
Been thanked: 11 times
Post by lexus-5 »
That would be an A-Main bumper....the taco looking one.
Remember it's either a runner or a shelfer. Everything else is just parts.
Check out my Gallery for more Collection Pictures http://www.rc10talk.com/viewtopic.php?f=77&t=20697
Patiofurnituregt
Post by Patiofurnituregt »
I think what gives the ball cups that glow in the dark green appearance is just because the plastic is semi translucent but once you thread the rod in and install it on the car it really isn't green tint seems to not be apparent.
Tim Tunnermann
Team Associated Design Engineer
Team Associated | |Reedy | XP Digital | JConcepts | Futaba | Makita | Kicker | LiveRC
slow_jun
Post by slow_jun »
Just notice now,are the towers only have one hole on the first release?as compared to the later release? Hmm..thats why the shock palcing is a bit odd..
― Confucius
REMJ666
Post by REMJ666 »
Looks good...You must have gotten a Tuesday thru Thursday kit because your not having issues with yours...I can't believe the glow in the dark ball cups :lol:
Those rear shocks are not right. Maybe forgot the internal spacer? Way too much shock shaft showing.
SFC K
Post by SFC K »
jwscab wrote:Those rear shocks are not right. Maybe forgot the internal spacer? Way too much shock shaft showing.
Nope, the directions called for two spacers per rear shock. I pretty sure I installed them per the instructions... :wink:
Jeff
tommy2c
Post by tommy2c »
Maybe they put the incorrect size and qty of spacers in the kit? p/n 6466 has an assortment of shock down stops. I think using a 1.32" shaft with a 1.32" shock body requires 3 of the black spacers per shaft. Looks like they used the short ones in the kit.
Unless it's a design change.
SFC K
Post by SFC K »
The ones in the kit were really thin and it asked for two per.
If you look in the picture where I have all the shocks laid out above, the black washer looking things were what it call for in the directions and were the only thing left over. I double check the part number in the directions too.
Jeff
Well that's gonna be a problem, they need to fix that. You'll want to go back and get three of those in there or a 5/8 spacer of some sort. Original was fuel tubing. Without it, you'll lose and chew up dogbones
Yeah definitely. You need 3/8" to 5/8" easily. Otherwise your gonna have a bad time :P
