YZ-10 Pavidis Tire Question
Vintagemishal
Post by Vintagemishal »
I know that Pavidis used Pro-line Square Fuzzies on his YZ-10 to win the 95' Worlds. He cut a set of rears down to fit the narrower front wheel. Question: Did Pro-line make a Square Fuzzie front 4wd tire after this? Also, what other tire would be appropriate for this car? Hole Shots are similar, but did not want to put a modern tire on it. Any advice is appreciated.
littleVETTE
Has thanked: 6 times
Been thanked: 10 times
Re: YZ-10 Pavidis Tire Question
Post by littleVETTE »
the only ones that i managed to find from proline's catalog is these: #8135 "pro-135" 4wd front fuzzie in 2.15". it's an ultra mini pin tire. it also comes in the "super soft" M2 compound. nothing in square pins for the front. you could always grab an extra set of rear square fuzzies and narrow them down yourself.
Vintagemishal
I have a pair of rear Flat Fuzzies that are a mini pin, so I guess if I could find something similar, that would work. I will look for the Fuzzies. Thanks
aip47-2008
Has thanked: 170 times
Been thanked: 23 times
Post by aip47-2008 »
littleVETTE
i think anything from that proline era wtih mini pins or squares are good on your pavidis. preferably in the m2 compound. there are a number of pavidis buggy builds around here that have them mounted.
aip47-2008
Vintagemishal
Thanks Aaron. The wheels showed up today and they look great! Also got the car completely disassembled, cleaned and reassembled. I have a new body for it and just need some tires.
Return to “Yokomo Forum”
