Need help to I.D. 2 12th scale cars
REMJ666
Post by REMJ666 »
Picked these up today for 50 bucks...I know one is a RC12 something and we think the other is made by Hot Bodies ??? Not sure...Which ones are they ???? Any help would be greatly appreciated...The photos start with the RC12 and end with the Hot Bodies...
SAM_1309 (475x356).jpg (178.39 KiB) Viewed 1430 times
SAM_1307 (475x356).jpg (181 KiB) Viewed 1430 times
SAM_1306 (475x356).jpg (161.61 KiB) Viewed 1430 times
SAM_1305 (475x356).jpg (170.87 KiB) Viewed 1430 times
SAM_1304 (475x356).jpg (179.71 KiB) Viewed 1430 times
SAM_1302 (475x356).jpg (185.55 KiB) Viewed 1430 times
SAM_1300 (475x356).jpg (195.77 KiB) Viewed 1430 times
SAM_1298 (475x356).jpg (168.25 KiB) Viewed 1430 times
SAM_1297 (475x356).jpg (180.02 KiB) Viewed 1430 times
SAM_1296 (475x356).jpg (167.97 KiB) Viewed 1430 times
MIKE VALENTINE
Re: Need help to I.D. 2 12th scale cars
Post by MIKE VALENTINE »
I believe there are RC12L3 and a HB cyclone 12
REMJ666
Post by REMJ666 »
Thanks...Both cars have a lot of dust from sitting with little run time...They should clean up well...My first 12 scale pan cars...
REMJ666
Post by REMJ666 »
Started cleaning the RC12 up and found a few things missing...I will call Team Associated tomorrow and order the missing bits and pieces...It is cleaning up well...Just hosed it down with WD40 and took a rag to her...Pulled the rear apart and found a crunchy bearing and one of the ride height adjusters was missing...But overall it is in great shape...Not 100 % minty but very little usage...
SAM_1316 (475x356).jpg (199.08 KiB) Viewed 1401 times
SAM_1315 (475x356).jpg (187.93 KiB) Viewed 1401 times
SAM_1314 (475x356).jpg (202.23 KiB) Viewed 1401 times
SAM_1313 (475x356).jpg (174.98 KiB) Viewed 1401 times
SAM_1312 (475x356).jpg (166.15 KiB) Viewed 1401 times
SAM_1311 (475x356).jpg (137.93 KiB) Viewed 1401 times
SAM_1310 (475x356).jpg (164.97 KiB) Viewed 1401 times
REMJ666
Post by REMJ666 »
So this was not supposed to be a build thread because every time I start one it never gets done...So I ordered some parts and the correct rear wheels for it and everything works...Took it completely apart and cleaned everything even better and replaced some of the screws that started to strip...I am waiting on the shock rebuild kit and turnbuckles...After that to find a matching set of front wheels and tires then to decide on a body or not to put a body on it ??? One last question about the rear...I bought a brand new gear and balls and when I put it together the spur weeble wobbles really bad....I sanded the diff rings before I put it back together...Could the diff rings be bad ????
SAM_1337 (475x356).jpg (154.46 KiB) Viewed 1357 times
SAM_1336 (475x356).jpg (150.49 KiB) Viewed 1359 times
SAM_1335 (475x356).jpg (163.31 KiB) Viewed 1359 times
SAM_1334 (475x356).jpg (147.99 KiB) Viewed 1359 times
teman
Been thanked: 6 times
Post by teman »
I'd say the spur is warped :(
Definitely get a body, there's tons of 12's to choose from 8)
-Kevin
REMJ666
Post by REMJ666 »
It is even worse...A bent axle :x
clm
Has thanked: 100 times
Been thanked: 205 times
Post by clm »
What about getting a body and partially painting it and leaving the main color clear to see the chassis? Something like painting the racing stripes. :)
Chris
Mini - T, LST, LST2, Crawler
Micro - Trekker, SCT, T
REMJ666
Post by REMJ666 »
I like the Jaguar body a lot...Just might put that one on it...
Users browsing this forum: No User AvatarTbot [Bot] and 4 guests
