What are RPM bumpers made from? Looking for plastic sheets
kink
Post by kink »
I would like to buy a sheet of black plastic which is made from the same material that bumpers are made from (like the RPM bumpers). Something tough, semi flexible, available in thin sheets of 1 or 2 mm. Not to make a bumper, but for other protection. Thanks
GARBO 1/8
teman
Been thanked: 6 times
Re: What are RPM bumpers made from? Looking for plastic shee
Post by teman »
It's their own plastic formula from what I understand, not sure what exactly it is.
Most people that fabricate their own bumpers use Kydex.
-Kevin
Sugar and spice, and everything nice.
No..... wait, that's what little girls are made of.
:mrgreen:
Been thanked: 3919 times
Kydex is easy to work with and cheap. It's what oooold bumpers were made of
You can get 6/6 nylon from McMaster Carr in sheets, it's the white dyable nylon basically what the original RC10's components were made of and is dyable. It's not cheap
Phin
Has thanked: 87 times
Been thanked: 248 times
Post by Phin »
RPM bumpers are injection molded not cut/machined.
kink
Post by kink »
That kydex stuff has too much texture to it. What smooth black plastic sheeting is there available? So long as it is tough-ish. I don't want to have to dye it black. Thanks
GARBO 1/8
Kydex or abs styrene are your best bets as they are formable. Not too many plastics you can form easily otherwise.
terry.sc
Has thanked: 7 times
Been thanked: 157 times
Post by terry.sc »
Depends on what you want it for. For tough and black, take your pick from nylon, acetal, delrin, HDPE, UHMWPE, RG1000, PVC, UPVC, etc.
If it's for a chassis protector then I would suggest HDPE, UHMWPE, or RG1000, the toughest and lowest friction materials.
kink
Post by kink »
Great info Terry, thanks! The part won't be formed. I just want to cut a small rectangle from a sheet. It will be used to protect the underside of my black nose piece from scuffs. Also I need to make it roughly 1mm (not measured it yet) thicker, so it buts up perfectly against a 3mm carbon chassis. This will then avoid an underside 'lip' edge.
Many thanks guys, I will have a search....
GARBO 1/8
