My old is new RC10 vintage racer build thread!
- Regular Member
Ok so I am starting a new build on an old buggy. I'm going to see how much new technology I can inject into this vintage dog. Lots of new tech AE stuff , such as VTS slipper clutch, B44 aluminum rear hubs with carbon "c" towers,b44 CVA axles, ceramic diff and thrust bearings, hex B4 wheels and I may even take a stab at "co-planar" steering like the new cars have. Any ideas or suggestions are welcome and appreciated!
Bitten by the R/C bug for the 2nd time...Team Associated until I die...
- Has thanked: 1129 times
- Been thanked: 3919 times
Re: My old is new RC10 vintage racer build thread!
My recommendation is lots of searching. There are tons of threads on optimizing using newer components
- Regular Member
I'm lucky enough to have a b4.2 , t4.1 and sc10.2 here that I can test fit parts from!
- Regular Member
So the pan chassis had been media blasted to relieve it of its nasty paint/powder coated filth and is being powder coated as we speak. Looks like the recipe will change for this build a little...if you see something that isn't going to work, feel free to let me know. All the electronics are things that i have laying around.Thanks in advance!
Chassis
stock tub powder coated semi gloss black
Stock buggy nose brace
Black nose tubes
B44 battery tray and straps (saddle pack)
Suspension
Dynotech arms (front and rear)
Carbon 3mm worlds shock towers
AE v2 shocks w/ kyosho big bore springs
B4 castor blocks
T4.2 hex front steering blocks and axles
B44 rear hubs with carbon "c" tower
Lunsford 3mm ti turnbuckles
Jconcepts ball cups
A&L ball bearing steering
B4 CVA axles and bones
T4 rear hex conversion
Transmission
Mip alum. B4 top shaft
Ceramic diff balls
B4 v2 slipper with vented hubs
Carbon transmission brace
Electronics
Orion r10 pro
Fantom ion pro 7.5
Airtronics 94152 servo
Futaba 3ch FAST receiver
Futaba 4pks transmitter
Chassis
Black nose tubes
Suspension
B4 castor blocks
Jconcepts ball cups
Transmission
Ceramic diff balls
Electronics
Orion r10 pro
Fantom ion pro 7.5
- 31 Replies
- 4979 Views
Last post by Ducati Mechanic
- 3515 Views
Last post by bluewormx
- 100 Replies
- 18491 Views
Last post by DerbyDan
- 1015 Views
Last post by Frankentruck
- 914 Views
Last post by cas22
- 2355 Views
Last post by delsami
- 1391 Views
Last post by Mja75
- 4600 Views
Last post by TRX-1-3
