Foam Donuts, what material???
- Seabass
- Business Member
- Been thanked: 12 times
Hey guys, foam donuts are pretty much nonexistant and usually difficult to find. My question is what is the material used for donuts? I have done some research on this topic but I keep coming up with nothign that really helps. I found some info on EVA foam which seems to be close but nothing to really confirm what is used. I am certain the material still is out there, I just need to figure out what that material is. Any help would be apprciated.
Jake
Jake
- Charlie don't surf
- Has thanked: 356 times
- Been thanked: 470 times
Re: Foam Donuts, what material???
Not hard to find at all- RC4Less, CRC, BSR all sell them-
CRC is the best outlet, a set of 1/8 foam doughnuts is around $17 and will do a full set of pan car wheels- of course, you need a tire truer-
- Seabass
- Business Member
Hmm, RC4Less shows nothing and I sent them an email, the reply was no more donuts in 1/10 other than the fronts. I emailed BSR and got a reply saying no donuts were being sold.
I did not know about the 1/8 donuts. Just looked at CRC and see the rear donuts for $17. Reg do you happen to know the dimensions of the donuts, they sell?
The 1/8 scale donuts are "rear" they are big in diameter and width, but you can make 2 rear, and two fronts out of one set-Seabass wrote:Hmm, RC4Less shows nothing and I sent them an email, the reply was no more donuts in 1/10 other than the fronts. I emailed BSR and got a reply saying no donuts were being sold.
- Has thanked: 1129 times
- Been thanked: 3919 times
And there is enough tire dust left over to really piss off the wife
Yeah, that's why I created a coroplast box that covers my tire truer (large maxmod with the carbide arbor) I can knock a 3.50" OD donut down to 2.50 in one pass
and 4 lb of dust!!
- markbt73
That was always my problem with buying untrued tires. Buy something, then grind half of it away into dust. Seems so wasteful.
- RC10th
- Has thanked: 52 times
- Been thanked: 1548 times
You can recycle 1/8 tires by soaking used foam off 1/8ths junk tires. What is too worn for them makes a nice new 1/10 tire.
- 978 Views
Last post by nvxwax
- 31 Replies
- 4603 Views
Last post by GreenBar0n
- 1463 Views
- 547 Views
Last post by Steve71
- 1610 Views
Last post by fordtransman
- 716 Views
Last post by Dadio
- 724 Views
Last post by Brandon G
- 1054 Views
Last post by hobbes
