rc10 newbie question
hello, im a pretty new to this rc stuff so i dont know what im doing yet, but i have a question reguarding an rc10 that i have. I'm pretty sure this has probably been asked before but can you run a traxxas brushless velineon 3500 motor with an rc10 3 gear stealth trans? if so will it hurt the gears or will i be fine? also if i cant run that motor i have a traxxas titan 550 motor in it will that work fine? thank you for answering these questions.
Re: rc10 newbie question
If you give it the full beans from stationery it WILL shred your gears.. Oh yes, 30 years old now almost
the stealth trans(3 gear) can handle a lot of power provided you pay attention to assembly, and adjust the slipper properly. Be sure the diff setting is correct and set the slipper on the loose side and sneak up to the desired setting.
- 1367 Views
Last post by RC104ever
- 929 Views
Last post by TRX-1-3
- 284 Views
Last post by mrlexan
- 1793 Views
Last post by MadZero
- 1832 Views
Last post by a01butal
- 1189 Views
Last post by jooles
- 1560 Views
Last post by TOLITS
- 87 Replies
- 13617 Views
Last post by JTSpeedDemon
