what size hex are mip set screws? i got a new t4 cvd set for my 10t but i don't think any of my tools fit, sae or metric.
i found it really odd.
MIP set screws
- Has thanked: 1129 times
- Been thanked: 3919 times
Re: MIP set screws
they could be crappy set screws, or your allen keys are worn. If you think they are worn, cut the end off cleanly with a dremel cutoff wheel and try them again. I have seen badly formed set screws for sure.
Re: MIP set screws
i thought they were .050". mine won't go and it's pretty new.
i'll look around for an unused allen and see how it goes.
thanks.
thanks.
Re: MIP set screws
if the .050" won't go in, it's possible there is crud in the hex of the set screw. check it out carefully, that's good, it means it's a tight tolerance, and you might just have to force it in there. at least the hex is too small vs. too open and useless.
- 1350 Views
- 568 Views
Last post by paul
- 1038 Views
Last post by 1911Colt
- 1959 Views
- 2670 Views
Last post by Peter_B
- 738 Views
Last post by ThomasH
- 802 Views
Last post by HS-YZ250
- 2738 Views
Last post by jcwrks
Users browsing this forum: juicedcoupe and 4 guests
