HOUGE TRAILING ARMS
HOUGE TRAILING ARMS
I found a NIB trailing arm kit so for what chassis will they fit directly with no problem.
Jerzi
Jerzi
- Has thanked: 36 times
- Been thanked: 1318 times
- RC10Eh
Re: HOUGE TRAILING ARMS
I agree , Houge only , I've seen a few arms installed with extended pads on other chassis . In fact I found that Associated carbon nerf bars could be used to adapt them to a tub car or composite chassis . Other than that , your options are limited . I have a chassis I could trace out the hole configuration if your interested ?
- limestang
- Has thanked: 100 times
- Been thanked: 249 times
There was a thread a while back where someone mounted trailing arms on a Sassy Chassis (Not sure of the brand). It worked and looked great. Limestang
- losiXXXman
- Been thanked: 5 times
I think the one your're thinking of is greenhell's. It was an A&L trailing setup I believe.
- losiXXXman
someone get jerzi the dimensions of the houge chassis so he can make one!
just keep it a little narrower up front so normal bodies will fit it.
- RC10Eh
Crappy pictures , but without tearing my car apart , this is the idea. Nerf bar holes seam to line up nice . I think with some creative Dremel work , two rectangular slots could be cut without sacrificing the pan to bulkhead mount . Just a thought .
- 2092 Views
Last post by mrlexan
- 1589 Views
Last post by duckhead
- 20 Replies
- 4969 Views
- 718 Views
Last post by mikedealer
- 1078 Views
Last post by InetRC
- 1075 Views
Last post by orangemazda
- 1001 Views
Last post by integra22t
- 1871 Views
Last post by Zac_F71
