XXT CVD question
XXT CVD question
Hi guys
I'm near to finishing my G+ however when doing the CVDs and mounting them i noticed that they sit rather far out of the outdrives. Is this normal?
- Been thanked: 4 times
- jamin
- Has thanked: 3 times
- Been thanked: 28 times
Re: XXT CVD question
Make sure you use the correct A+B spacers inside the shocks to achieve the proper droop, it also depends what hole you have mounted the shock in the wishbone. You should be using middle hole on the wishbone, the position on the tower wont make a lot of difference.Caine wrote:Hi guys
The golden rule is that the pin must sit inside the outdrive at full droop, if not it may pop out.
If you use the kit settings it should be fine
Team Losi: XX-CR | XXT | XXT-CR Graphite+ | XX4 | Street Weapon IWC Edition
- Has thanked: 170 times
- Been thanked: 23 times
Do you have the correct CVD kit?Caine wrote:Hi guys
MIP made different kits for the XXT & the XXT CR or Graphite +
- jamin
Hmmm, I am sure that the dog-bone length will be the same for all variants of the truck, I don't think the distance between the outdrives and the hub changed at all, not even for the CR hubs.aip47-2008 wrote:Do you have the correct CVD kit?Caine wrote:Hi guys
Thanks for the input guys, all sorted now
Just needed to shim on the back of the axle as thunderstrike said, a lot happier with where they are lying now. Just felt that when i put the power down i could of ended up with broken outdrives!
Should have it finished this weekend so will put some pictures up in my original post
- 127 Views
- 1055 Views
Last post by SoCalSnakeEyes
- 413 Views
Last post by Toyotachris1982
- 437 Views
- 770 Views
Last post by Ruffy
- 32 Replies
- 2106 Views
Last post by mrlexan
- 970 Views
Last post by Zedmaster
- 190 Views
Last post by NthNackenBlack
