I got the chassis off epay; 0.99 for the chassis and 0.99 for the nose because all the countersunk holes on the chassis had been enlarged, so cutting it up didn't seem so terrible, but still a little painful when i actually did it.
that would be interesting, would just need to custom make a rear motor plate to accommodate everything and for the front, that would be a little more trickylosiXXXman wrote:I think that a B4 built on a gold chassis was brought up quite while back, but I never saw any pictures of it done! Looks good. I kind of have an opposite idea going, its why i made a thread asking about a B4 chassis. I want to take an old cars suspension and trans and drop them onto a new cars tub.
That's ambitious.tommykart wrote:...Only problems i have is with rear travel, dimensionally is is exactly like the b4, i am not sure if i have too much droop in the rear that the cvd bottoms out against the stops in the out-drives before the chassis bottoms out.
If you mean the cvd hits the inside of the drive cup before the shock bottoms out, then you definitely need shorter cvd shafts. Otherwise they will bend from slamming into the drive cups under heavy compression (landing after a jump) and cause further problems. If you have B4 cvd's then try associated B44 cva's, the drive shafts are a few mm shorter. Unfortunately you'll need to buy another whole set because the pivot/coupling is switched on the axle and shaft between cvd's and cva's.tommykart wrote:...Only problems i have is with rear travel, dimensionally is is exactly like the b4, i am not sure if i have too much droop in the rear that the cvd bottoms out against the stops in the out-drives before the chassis bottoms out.
scr8p wrote:does the trans sit too high and now there too much of a telescoping effect in the outdrive?
Bing [Bot] and 4 guests
