Parts Sites
- DMAT
- Been thanked: 4 times
Parts Sites
so I was going thru a bunch of sites searching for parts for the car. figured id post them here for others if they were looking. This mostly for the original rc10 so no clue if it works on other models. Some of the sites with just url listed just had too much to sort thru so i left it alone.
please add more info to this if you have it.
http://store.robobugs.net/index.php?main_page=index&cPath=26_24
http://www.amainhobbies.com/
http://www.rcplanet.com/
http://www.jconcepts.net/store/
http://www.kippshobbies.com/
http://www.dissymmetry.com/www.Aero-RC.com/rc10-order.html
- some nice aluminum wheels
http://www.fibre-lyte.co.uk/
- carbon fiber tub chassis
- carbon fiber front shock tower
- carbon fiber battery brace
- carbon fiber transmission brace
http://www.bartspartsrc.com/index.html
- many aluminum parts. need to contact to get a better list of what all he has.
http://www.jcracingproducts.co.uk/products/
- 2.2" wheels that fit 1/4" axle (needs 3/16"x5/16" bearing)
http://miponline.com/store/mip1007.html
- MIP CVD kit #1007
http://www.rpmrcproducts.com/products/assoc/front.htm#RC10
- various rc10 front arms
http://www.rpmrcproducts.com/products/assoc/rear.htm
- various rc10 rear arms
http://www.pargustore.com/alloy-parts/associated/rc10.html
- 2.2" alloy jelly been rims
- alloy shock tower clamps
- 1/4" axle hex adapters (remake of hpi adapters)
- alloy rear arm mounts.
http://rccarbonworks.com/store/index.php?route=product/category&path=20_36
Carbon Fiber parts
- main chassis
- rear shock tower
- front shock tower
- transmission brace (6 gear & stealth)
- battery strap (normal & lipo)
- Extended rear axle kit (3/16" axle, possible works with traxxas)
- 3/16 x 3/8 bearing for extended axle kit
- 1/8, 3/32, 5/64 ceramic diff balls
http://vintageteamaandl.com/
- bell crank
- aluminum rear trailing arm conversion kit
- slipper clutch for stealth tranny & belt driven tranny.
- dress up kit.
http://www.hot-racing.com/index.cgi?c=143
- pinion gears (32 & 48 pitch)(8-24 teeth)
http://vortexhobbies.com/index.php?keywords=rc10&x=0&y=0
- rpm front a arms, different version
- rpm read a arms, same as above
- battery cups
http://www.stormerhobbies.com/cgi-bin/searchpn.pl?pn=&dterm=rc10&dterm2=&dterm3=&dterm4=&mterm=&instock=&withpic=&oterm=&useoz=&advanced=&sthumb=on&catified=&catiflo=&weighed=&parents=&uterm=&smode=0&stype=&man=&page=5
- stealth tranny gears
http://www.hobbywarehouse.com/s.nl?search=rc10&x=9&y=11
- CVD Kit (cheaper than manuf. site)
- rear A arms
- 1.02" rear shocks
- steel idle gear (26 tooth for rc10gt) compatible?
- caster blocks (30 deg)
- inline steering blocks
- rear hub carriers
http://www3.towerhobbies.com/cgi-bin/wti0095p?FVPROFIL=++&FVSEARCH=rc10&search=Go
- drag link
- rear shocks (1.32" & 1.02")
- front shocks 0.56"
- front bumper
- front A arms
- center link
- rear arms
http://www.activepowersports.com/search.php?search_query=rc10&x=0&y=0
- turnbuckles
- battery cups
- wing kit
- shock bushings
- MIP CVD Kit
- front A arms
- Wide front A arms
- spring cups
- rear A arms
- shock rebuild kit
- idler gear
- Front suspension mount
- inline steering arm
- drag link
- rear shocks 1.02"
- center link
- drive gear shaft
- front shock strut
- alloy wing mounts
http://www.mammothhobbies.com/SearchResults.asp?Search=rc10
- front suspension mounts
- inline steering arms
- turnbuckles
- wide front A arms
- battery cups
- wing kit
- drive gear shaft
http://www.speedysracingparts.com/RC10.htm
- carbon fiber body part kits.
http://www.ebay.com/itm/FRONT-WHEEL-AXLE-Wide-Track-Adapter-Tamiya-5x11-Bearing-RC10-RC-Team-CRP-1557-/350692174706?pt=US_Radio_Control_Control_Line&hash=item51a6e1eb72
- front wheel axle wide track adapter. (5x11 bearings, fits traxxas)
http://www.rcsoup.com/2013/01/aluminum-original-rc10-stealth-transmission-case/
did anybody manage to get one of these aluminum rc10 stealth transmission cases?
made by rogue element components
http://www.rwracing.co.uk/cars.html
- various gears, inquiring about transmission gears that were made of plastic.
http://www.averystcards.com/nsearch.html?query=rc10&searchsubmit=Go&vwcatalog=averystreetcards&.autodone=http%3A%2F%2Fwww.averystcards.com%2F
- idler gears for the 6 gear transmission
- MIP CVD kit #1007
Carbon Fiber parts
- main chassis
- rear shock tower
- front shock tower
- bell crank
- dress up kit.
- battery cups
- rear A arms
- 1.02" rear shocks
- rear hub carriers
- drag link
- front bumper
- front A arms
- center link
- rear arms
- turnbuckles
- battery cups
- wing kit
- shock bushings
- MIP CVD Kit
- front A arms
- Wide front A arms
- spring cups
- rear A arms
- shock rebuild kit
- idler gear
- drag link
- rear shocks 1.02"
- center link
- drive gear shaft
- front shock strut
- alloy wing mounts
- turnbuckles
- wide front A arms
- battery cups
- wing kit
- drive gear shaft
Re: Parts Sites
Sabula has some parts, ordered some from him. Noticed he just put up new rear arms lately.
Learned by accident, typed in the part number for original stealth diff rings, Well there still used in the b44, same part number.
RPM also re-released the mini front bumpers also.
Funny thing, Was at ultimate hobbies on tuesday, Saw 2 original fiberglass shock towers, and well they had brand new header tags, (there has een 2 generations of headers since they were out. and they had brand new price tags, which means the sghop received them from associated with in the last few months.
- myfordcnc
Re: Parts Sites
Thanks for posting this. For some I'm sure they know about these sites but for me this was really helpful, great to see them listed in one place. Good looking out!
- RC104ever
Re: Parts Sites
Awesome! Thanks for doing this up, great reference.
- Chris
Lots of cars...so many cars
Re: Parts Sites
Great accumulation. This makes the replacement searches much easier. As a matter of note, I have absolutely had ZERO luck with contacts to Barts Parts site, email, text, or either phone number. Any one else getting through?
ALL OVAL RACING:
SC10 Late Model
SC10 Modified
SC10 Bomber
Cobra Nemesis Sprint
B4 Street Stock
TC3 Late Model
SC10 Late Model
SC10 Modified
SC10 Bomber
B4 Street Stock
TC3 Late Model
- DMAT
Re: Parts Sites
decided to test out a few parts. Extended rear axle kit from carbon works does work with traxxas. you do need to buy 3/16x3/8 bearing for them. A pin was needed and it felt like the roll pin was too big and a traxxas pin was way too big but it did allow for a hex drive to slide on an put a traxxas wheel on. I'm guessing any wheels that would be compatible with a 12mm traxxas hex would work too.
- 8342 Views
Last post by Tadracket
- 755 Views
- 19 Replies
- 2046 Views
Last post by marlo
- 1322 Views
Last post by RichieRich
- 1207 Views
Last post by Taylorm
- 558 Views
Last post by GreenBar0n
- 1987 Views
Last post by alcyon
- 1372 Views
Last post by Lavigna
Google [Bot] and 14 guests
