Rogue Ready!
esaresky75
Rogue Ready!
Post by esaresky75 »
I think I have everthing for a Rogue Stealth with B4 Slipper. :D :D
Burn more coal - UnderGroundMiners.com
askbob
Re: Rogue Ready!
Post by askbob »
Sweet! We need close up shots of that shiny case... :)
myfordcnc
Re: Rogue Ready!
Post by myfordcnc »
Esaresky,
Whats the the part number on that top shaft? I went to go and build up my alum case today and realized I have a 2.65 conversion shaft. Would like to hunt for the stock shaft. Thanks
esaresky75 wrote:I think I have everthing for a Rogue Stealth with B4 Slipper. :D :D
SoAzRC
Re: Rogue Ready!
Post by SoAzRC »
... any chance you could list all the numbers so I can make sure I got everyting? I don't build 2.25 alot...
ALL OVAL RACING:
SC10 Late Model
SC10 Modified
SC10 Bomber
Cobra Nemesis Sprint
B4 Street Stock
TC3 Late Model
klavy69
Moderator
Has thanked: 639 times
Been thanked: 294 times
Re: Rogue Ready!
Post by klavy69 »
myfordcnc wrote:Whats the the part number on that top shaft?
associated's top shaft for an rc10b4 is part number 9601 if that helps...
myfordcnc
Re: Rogue Ready!
Post by myfordcnc »
So a b4 transmission is 2.25:1 ratio? Are you building one of these alloy cases up too? I looked over some old posts but frankly after an hour or two my eyes kinda glazed over. :? :mrgreen: I'll hunt that part # down and get it one any way. That way I'll have it and be able to justify another build :) Thanks for the info Todd.
Re: Rogue Ready!
a b4 is a 2.60, but all of the ae topshafts have the same tooth count.
myfordcnc
Re: Rogue Ready!
Post by myfordcnc »
scr8p wrote:a b4 is a 2.60, but all of the ae topshafts have the same tooth count.
Scr8p,
Then I can assume that the top shaft I have is definitely not an AE manufactured shaft. AE varied their ratios using the diff gear and idler? So all I have to do is find an OG top shaft?
esaresky,
Sorry if I've some what hijacked your post. I look forward to seeing it built and what your going to put it into.
Re: Rogue Ready!
your 2.65 conversion shaft is from rpm. it's not an ae piece. it's just the diff gears that change the ratio.
2.25 - rc10/10t/ds
2.40 - b2/b3/t3
2.60 - t2/gt/b4/t4/sc10
myfordcnc
Re: Rogue Ready!
Post by myfordcnc »
Well that would explain the RPM case it came in then. :oops: :lol: I thought they were just making cases. Now I'm on the right track. thanks.
Users browsing this forum: No User AvatarBing [Bot], No User AvatarGoogle Adsense [Bot] and 7 guests
