Flargen wrote:Another update: after reviewing the RC10B4.2 instruction manual, it appears as though you could do the B4.2 slipper assembly as well:
- ASC9601 x1 - Top shaft
- ASC9603 x1 - Slipper pad
- ASC9604 x1 - Slipper hub (internal)
- ASC91176 x1 - VTS slipper housing
- ASC91177 x2 - VTS slipper pads
- ASC91178 x1 - VTS slipper plate
- ASC91179 x1 - VTS slipper hub, outer
- ASC9739 x1 - Slipper spring
- ASC7486 x1 - V2 slipper washer
- ASC6629 x1 - Locknut (5-40)
Now to decide which route to take...
I did the B4.2 slipper. My son has a RC10B4.2, so I just ordered all the parts from his manual. With the B4 top shaft everything works perfect. The shaft does stick out too far for the original cover, but I've found that the B4.2 cover (ASC7461) works great for me. Without mod you can only use the top screw, but they are stiff plastic, and so far that has not been an issue. Besides the one screw thing, it's just a much nicer cover.
I don't have any pictures uploaded at the moment, or I'd post. I'd promise to post pic, but we see how that works out sometimes.
[Edited 2013/03/29 to remove comment about Stealth Slipper Pad which was incorrect and is now covered in thread:
http://www.rc10talk.com/viewtopic.php?f=38&t=30592]
