Thought you guys might get a kick out of this.
Got some A-6209 8-32 x 1/2" Aluminum Flat Head screws in from Horizon this week, sorta....
See the picture
Check out these new Losi chassis screws
- mytimac
- Business Member
- Has thanked: 7 times
- Been thanked: 56 times
- Attachments
- MagneticAlum.jpg (16.63 KiB) Viewed 1128 times
- Has thanked: 1129 times
- Been thanked: 3919 times
Re: Check out these new Losi chassis screws
I posted up that same basic rant a while back. You'd think they would at least not call them aluminum
gomachv wrote:Well now that my Losi screws showed up I am a bit pissed at Losi.
I remember the screws being black, but this is 12 years later- OK I can accept "raw" aluminum even tho the pic shows black. Here they are......
Wow...they look OK but very shiney. Heavy too. Hmmmm a little test......
Yup they are STEEL. Damnit. Losi lies. You'd expect them to at least change the label
- a01butal
- Has thanked: 34 times
- Been thanked: 40 times
I use these and they are definitely aluminum:
http://www.fastener-express.com/black-flat-head-phillips-machine-screws-100-degree.aspx
This is all very interesting!
- mytimac
- Business Member
[quote="gomachv"]I posted up that same basic rant a while back. You'd think they would at least not call them aluminum
Did you contact Horizon about this? I did, hopefully they will get it changed. I will give them a little bit and then try another contact to see if they can get things corrected.
- sgirouard
I was annoyed with a set of stainless steel screw sets I bought off Ebay. The 8-32 screws don't countersink 100% because they have the slightest "sidewall" to the head of the screw. Similar to the ones in the tops picture. Luckily I found a couple packages of old aluminum screws in an old tacklebox I used to use when I raced.
I really wanted to use stainless. The rest of the screws are great, just cant use the 8-32's.
- 3021 Views
Last post by aconsola
- 1315 Views
Last post by rctenracer
- 31 Replies
- 3707 Views
Last post by Doc J33P
- 829 Views
Last post by Dr. Robotnik
- 522 Views
Last post by RCveteran
- 2552 Views
Last post by clm
- 1349 Views
- 977 Views
Last post by FasterLouder
