xxx-sct rear rims are the same fit as??
Forum rules
- longboardnj
are xxx-sct rear rims are the same fit as sc10rs ?? i hope so, if no what others do they fit?
- JK Racing
- Has thanked: 139 times
- Been thanked: 246 times
Re: xxx-sct rear rims are the same fit as??
Nope...too big of an offset, not sure how much.
RS and SCTE are "zero" offset wheels, there is a larger hex you can put on the XXX truck to use the zero offset wheels (what I did).
All my SC trucks use zero offset, that way I can share tires amongst all my trucks.
- longboardnj
All my SC trucks use zero offset, that way I can share tires amongst all my trucks. thats kinda my plan..JK Racing wrote:Nope...too big of an offset, not sure how much.
Nope...too big of an offset, not sure how much. so will the xxx-sct rims work on a sc10rs and just be a bit wider?
RS and SCTE are "zero" offset wheels, there is a larger hex you can put on the XXX truck to use the zero offset wheels (what I did). what options do i have for this? plastic,or metal. oem,or aftermarket? do you need to change the axle ? if no is there still plenty of threads left to bolt on the rs rims?
any options for running front hex on losi sct-xxx ?? can i run sc10rs front hex set up? if yes then do i use sct-xxx rear rims or sc10rs rims?sorry alot of ??s i thought sc10 and sct-xxx had same front wheels now i find out they dont im in a bit of a jam
- JK Racing
proline, exotek and I think CRC (couldnt find it though) all make kits for 12mm hex up front. Worst case, just steal some slash carriers & knuckles and open the hinge pin hole up a touch. I did mine with some older kyosho parts, but they will be coming off, it doesnt allow me to turn sharp enough. You may be able to use the SC10RS front parts, I never tried.
http://www.exotekracing.com/xxx-sct-12mm-axle-and-hubs/
http://prolineracing.com/performance-parts/xxx-sct/xxx-scb-front-inboard-hub/
- Charlie don't surf
- Has thanked: 356 times
- Been thanked: 470 times
Far from vintage...and soon to be moved to the tech section...., but why not just drop the captured bk axle assy' with a 22sct axle?
- longboardnj
Far from vintage...and soon to be moved to the tech section... yea please do, my bad sorry. i dont mean to do this i just started really getting into new stuff and id had all vintage stuff . i would always just ask ??s without thinking if its in a vintage section.Charlie don't surf wrote:Far from vintage...and soon to be moved to the tech section...., but why not just drop the captured bk axle assy' with a 22sct axle?
why not just drop the captured bk axle assy' with a 22sct axle? im not 100% sure what you mean ? im thinking your saying get rid of everything on the end of the arm xxx-sct and just run the 22sct set up. if yes, will this work? can i use a 0 offset rims then?
im rethinking losi now that i realize alot of stuff (bearing size wheel offset and other stuff ) is different then ae.(i always thought vintage ae and losi ran the same size bearing id check but i sold all my vintage losi) i have alot of ae stuff thats why i wanted to put a sc10 front end on. if i sell the losi in the future i will put the losi back stock and have extra ae parts
To be fair we don't have a "new" section.
The BK buggy used a short hex or axle that was a xxx style knuckle and a bearing carrier hub instead of an axle carrying knuckle. Use that knuckle (that has bearings in the knuckle) and use a 22sct axle that rides through the knuckle
- JK Racing
isnt the 22SCT metric? I know my 22 buggy is. BK carrier is imperial.
- longboardnj
all good it really was a tech ? anywayTo be fair we don't have a "new" section.
looks like things are not what they seem to be.. i knew traxxas slash 2wd and durango 2wd were different wheels . i thought all the rest would be the same. looks like its almost best to stay oem
- 655 Views
Last post by 59burst
- 616 Views
Last post by SteveK
- 22 Replies
- 2192 Views
- 850 Views
Last post by sgirouard
- 1959 Views
- 3455 Views
Last post by tamiya
- 791 Views
Last post by klavy69
- 1980 Views
Last post by durb69
