rc10/tamiya wheels adaptors
- Been thanked: 12 times
Hi Experts,
I have gold pan A RC10 chassis.
I want to fit tamiya gold hotshot rims to it.
Will the team CRP adaptors (front and rear) work? Specifically, I'm referring to the Fox rear adaptors and the front axle mods both by CRP.
If not, can anyone suggest some other adaptors or shiny rims I can get for a reasonable price?
Thanks
Thanks
Re: rc10/tamiya wheels adaptors
fox adapter can let you used fox wheel on rc10 but fox gold wheel are rare
you can use blackfoot rear adapter fit with frog chrome wheels
- Phin
- Has thanked: 87 times
- Been thanked: 248 times
I suppose you could use the Hotshot to Kyosho wheel adapters from CRP with the 1/4" axle to 12mm hex adapters from HPI to mount Hotshot wheels on the rear of an RC10. However, since the front wheels on a Hotshot don't use bearings in the wheels you'd not only have to use the CRP and HPI adapters on the fronts, you'd have to switch to the B4.1/SC10 front hex knuckles.
With all those adapters the offset on the wheels is likely to be out of whack.
- Been thanked: 81 times
Just a heads up on the fox and blackfoot adaptors from CRP. They work with 1/4 axles but you will need the barrel nut to make them work. CRP offers barrel nuts only for meteric threads. These are the barrel nuts.
http://www.ebay.com/itm/Team-Associated-RC10-Blackfoot-Rear-Wheel-Adaptors-/380190031792?pt=US_Character_Radio_Control_Toys&hash=item5885177fb0
- Attachments
- 140.jpg (3.97 KiB) Viewed 2649 times
- Has thanked: 11 times
- Been thanked: 6 times
Before i go and make another thread, figured I'd ask here.
I order a set of CRP wheel adapter and front axles to mount blackfoot rims to a gold pan. Would I be able to mount Tamiya Hornet rims and tires to the gold pan instead of the black foot rims & tires ? Dont want to go buy a set if they wont fit.
Original Blackfoot / Monster Beetle wheels used the same adaptor as the Frog, Hornet etc, so YES, there is no reason why the rears wont fit..
However, the front Blackfoot wheels used a longer axle, which will be too long to suit the Hornet front rims.. You will need to either buy these CRP axles http://www.ebay.com/itm/FRONT-WHEEL-AXLE-Wide-Track-Adapter-Tamiya-5x11-Bearing-to-RC10-RC-Team-CRP-1557-/350692174706?pt=US_Radio_Control_Control_Line&hash=item51a6e1eb72
OR...
You can still use the Hornet front wheels with the original RC10 front axle and bearings with the use of a bearing adaptor that is supplied with all original RC10 gold pans..
Bearing adaptor - http://www.ebay.com/itm/associated-RC-10-buggy-vintage-front-wheel-bearing-adapters-tamiya-/140940936570?pt=US_Radio_Control_Control_Line&hash=item20d0bc057a
Cheers
OR...
Cheers
Thanks for that information. A few of my Rc10's will be sporting Tamiya Hornet rims and tiresStumpy wrote:Original Blackfoot / Monster Beetle wheels used the same adaptor as the Frog, Hornet etc, so YES, there is no reason why the rears wont fit..
OR...
Cheers
Well, my order from Team CRP came in from ebay today.
I ordered #1552 , was told Id be able to mount Tamiya Blackfoot Rims to a Rc10. The front axles are not wide enough to go through the bearings on the blackfoot rims.
Im almot positive i can use them to mount buggy rims. Now all i need is Buggy rims n tires AND the correct parts to mount black foot rims to the front.
- Has thanked: 36 times
- Been thanked: 1318 times
- longboardnj
if you look up teamcrp on ebay they list some things as free shipping then when you click on the link they give you a shipping charge. just a heads up.
- 318 Views
Last post by vintage racer
- 889 Views
Last post by karnivool
- 915 Views
Last post by littleVETTE
- 572 Views
Last post by fordtransman
- 639 Views
Last post by Mr. ED
- 2255 Views
- 2098 Views
Last post by SteveK
- 436 Views
Last post by a01butal
