Lipo charging questions.
O.K. so I'm finally to the point of having to charge my new LiPo battery and try my re-build out. I have a digital balance charger and was reading the instructions and have a few questions. First, they give me the option of a regular charge, balanced charge or quick charge. Which should I use and whats the pros and cons. The battery in a Gens Ace 5000 40C what can I expect for a charge time and run time with a 3900kva motor? Any other LiPo tips and tricks would be appreciated.
Re: Lipo charging questions.
balance charge at 1c (5amps because it's a 5000mah battery).
charge time depends on how much juice is in there to start with.
make sure your esc's lipo cutoff is enabled, you don't want it to discharge under 3 volts per cell / 6v total for 2s.
you'll probably get 20-25 minutes, maybe more, maybe less.
Don't forget to put the battery on set for "storage" when you are done for the day. LiPos do'n't like to be stored completly full or discharged. Somewhere around 8.6 volts.
The voltage of a fully charged 2S liPo will be 8.4 volts MAXIMUM..mark in wi wrote:Don't forget to put the battery on set for "storage" when you are done for the day. LiPos do'n't like to be stored completly full or discharged. Somewhere around 8.6 volts.
I would suggest that "mark in wi" has made a typo, and meant to type 7.6V as a suitable storage voltage..
Personally I store my LiPo's at about 7.8 Volts.. When I raced on a regular basis, I found that I would use approx 2000mA out of a 5000mAh pack, so I would just store it with whatever charge was left in the pack..
Please do not attempt or allow a 2S LiPo to charge to 8.6 volts..
Mark..
- 20 Replies
- 2755 Views
Last post by THEYTOOKMYTHUMB
- 2493 Views
Last post by Beatnik
- 41 Replies
- 6773 Views
Last post by Diamond Dave
- 21 Replies
- 2248 Views
Last post by Lonestar
- 2397 Views
- 1173 Views
Last post by tim.sanderson
- 815 Views
Last post by iVTEC4LIFE
- 23 Replies
- 2472 Views
Last post by klavy69
