RC10CE Stealth Bearing Upgrade List....
General info, Q&A.
Claymore5150
Post by Claymore5150 »
Ok gang, here's the parts list, etc., to upgrade a bushing Stealth CE up to bearings for a wallet crushing $17.00 + shipping. Yep, one buck per bearing. Gotta love it!
http://www.avidrc.com
For the Stealth tranny:
4ea 3/16 x 3/8 unflanged metal #R166ZZ
2ea 3/8 x 5/8 unflanged metal #R1038ZZ
2ea 5/16 x 5/32 unflanged metal #R155ZZ (diff gear)
4ea 1/4 x 3/8 FLANGED metal #FR168ZZ (rear hub carriers)
1ea 3/16 x 5/16 unflanged metal #R156ZZ (slipper clutch)
Front Wheels:
4ea 3/16 x 3/8 unflanged metal. 2 choices...
with rubber seal on ONE side to keep dirt out #R166-RSZZ
or standard metal #R166ZZ no price difference...maybe a touch more friction on the rubber sealed, but may last longer...plus you can exacto the rubber off if you don't like it and you end up with R166ZZ anyhow. :)
Steering: ONLY If you have upgraded to the Worlds car steering they take the same Flanged metal as the rear hub carriers...
4ea 1/4 x 3/8 Flanged metal FR168ZZ
You may or may not need a bearing spacer.
Hope this helps some people out.
Itchy Trigger Finger and RC Throttle Junkie
R.O.C.C.K. Proud Member
B.B.R.C. Proud Member
94CErunner/T2runner/2wd Slash LCG/
Brandon G
Re: RC10CE Stealth Bearing Upgrade List....
Post by Brandon G »
Thankyou, I was just about to go through the manual and spec out all the brngs I would need, but you already did the work for me!
