Dyna Storm wing mounts
cunawarit
Post by cunawarit »
Hi guys, how easy are these to find? I'm no Tamiya expert I'm afraid, and I've never tried to buy any rarer Tamiya part like this.
I don't want it for a Dyna Storm I'm actually trying to mount a Wing on a Traxxas Bandit like it would have been mounted on a TRX-1.
Basically trying to achieve this sort of wing mount:
Using a shock tower sort of like so:
And the Dyna Storm wing mount seemed ideal:
So? Impossible to find? Barking up the wrong tree? Is there an easier solution?
Been thanked: 3919 times
Re: Dyna Storm wing mounts
Pan cars use these, if you don't care about the look of them I would try there first
RichieRich
Has thanked: 39 times
Been thanked: 25 times
Post by RichieRich »
Those are hard to find. I found a couple of sets of the BRP bullet wing mounts at a hobby shop. Pretty sure those are discontinued but you might find some somewhere or on ebay.
cunawarit
Post by cunawarit »
OK cool :)
Found these in stock: http://www.lefthander-rc.com/catalog/product_info.php?cPath=21&products_id=444
Now oval RC racing here in the UK is totally different than it is the USA. So sadly I can't get hold of the part locally...
Well from my reading we dont use them here anymore either lol! That's how long i have been away!
cunawarit
Post by cunawarit »
LOL! OK :) It doesn't seem like the most complex part in the world, I am sure there's an alternative somewhere with everyday hardware shop bits...
Well, a standoff (i get them from McMaster carr) has 2 threaded ends and comes in many lengths. If you drilled the wire holes in the side you could put a screw in one side and a grub in the other, it would cost you under a $1 for the standoffs. They are aluminum. Not sure about metric, but they have 4-40
Mad Racer
Post by Mad Racer »
Used on the Top Force too.
Hard to find now & if you do they cost a arm & a leg.
I use Losi wing mounts or Kyosho Lazer zx5.
Way better set up. No buttons or wire to deal with.
http://www.ebay.com/itm/Losi-XXX-BK2-XX4-Wing-Mount-Set-/350589297008?pt=Radio_Control_Parts_Accessories&hash=item51a0c02170
http://www.ebay.com/itm/Kyosho-Lazer-ZX-5-Bumper-Wing-Stay-Set-/140833008856?pt=UK_ToysGames_RadioControlled_JN&hash=item20ca4d2cd8
if you chose a standoff from mcmaster, I'd probably use 93330A515, 7/16" long, #4 screw. Of course, if you wanted metric, you could always do that. check electronic suppliers in your area, they have to sell standoffs. usually referred to as PCB standoffs, etc.
cunawarit
Post by cunawarit »
Thanks for the tips guys, it looks potentially doable :) And dirt cheap :D
Did you ever find what you were looking for? I found a pair of basic wing mounts at the lhs and grabbed em, if you need them let me know
cunawarit
Post by cunawarit »
gomachv wrote:Did you ever find what you were looking for? I found a pair of basic wing mounts at the lhs and grabbed em, if you need them let me know
I ended up using Team-C wing mounts, worked a treat!
Return to “Tamiya Forum”
