Shelf queens and oils
newob
Post by newob »
Who leaves shock oil in their shelfers? Leaving shocks dry seems the cleanest option to me but curious what others are doing.
Has thanked: 356 times
Been thanked: 470 times
Re: Shelf queens and oils
Dry for me-
RedScampi
Post by RedScampi »
It varies for me. If the shocks are known to be prone to leakage - none. Otherwise I have oil in mine.
Gary
I put a few drips of oil in to assemble and make them smooth, but that's all. Definitely not 'dry', but empty.
Lowgear
Has thanked: 121 times
Been thanked: 795 times
Post by Lowgear »
Either empty or a few drops of oil.
newob
Post by newob »
jwscab wrote:I put a few drips of oil in to assemble and make them smooth, but that's all. Definitely not 'dry', but empty.
good point. green slime work well also.
I'll vote for oil-filled...yeah they might leak over time, but that oil is the only thing keeping the O-rings and rubber diaphrams (in the case of Kyosho Golds, anyway) soft & supple.
I've disassembled decades-old Kyosho Golds and found the rubber parts inside almost as new as the day they were installed. Storing shocks dry will likely result in dried-out, cracking, or deformed rubber parts. Not that it matters for a shelf-queen, mind you...
Been thanked: 3919 times
When you pull a car down off the shelf to show someone the first thing they do is play with the suspension. So for me, its oil
gomachv wrote:When you pull a car down off the shelf to show someone the first thing they do is play with the suspension. So for me, its oil
LOL I was thinking that, too..."Look at this rare, amazing high-end RC car model...but it handles bumps like a Tamiya Hornet! Boingy-boing..." :mrgreen:
Mad Racer
Post by Mad Racer »
I never thought of that.
Very good topic. Well all of mine have oil in them. As Marc said they will dry rot otherwise.
Yes first thing anyway does is play with the suspension. I also put in a steering servo. Dead or alive just to stop the wheels flapping around when picked up. :lol: :lol: :lol: :lol: :lol:
Has thanked: 1737 times
Been thanked: 1145 times
As some here would attest, most of my runners have variable amounts of oil in the shocks..... mostly none :oops:
Perhaps I'm not the best to ask? :lol:
Lowgear
Post by Lowgear »
How about no oil but coating the rubber parts in green slime like newob mentioned?
sheriff
Post by sheriff »
I'm no expert on the subject, but I imagine if a shock would perhaps leak, it would do so only under stress (getting used a lot)
If it's just sitting on a shelf, I'd have thought there wouldn't be a problem with leaking, due to lack of pressure on the seals.
RC104ever
Post by RC104ever »
Well, I don't have a shelfer per se but when my old RC10 came out of a box it still had lots of oil in the shocks and they hadn't leaked in 20 years. So I vote for oil filled :mrgreen:
- Chris
Lots of cars...so many cars
If you ever build a set of HG clearbodies, build them dry or pay later-
Users browsing this forum: User avatarjuicedcoupe and 6 guests
