Gearing your RC10
joel45acp
Gearing your RC10
Post by joel45acp »
I'm not sure if this is the correct place to ask, but how are you gents gearing your Goldies if you're running a 17.5T sensored motor with stealth tranny. I just need a ballpark. Currently, I'm running nimh and Gens Ace 30C batteries, HK 35A sensored ESC and Leopard 17.5T sensored motor. Thanks in advance guys.
In Christ,
Joel C.
JK Racing
Has thanked: 139 times
Been thanked: 246 times
Re: Gearing your RC10
Post by JK Racing »
Joel, I am assuming blinky, and a bit of the gearing depends upon the track. I run a bigger indoor track (well big for our area) and I am at 30/69.
Start a little lower than that (maybe 28/72 range) and run 3~4 minutes, check temps. Keep it under or at 150 (under is better). Check the speedo/capacitors (if your speedo has 'em) and battery as well. Those items should never get that high, maybe 120-130 range and start worrying.
remember for gearing, 3 on the spur = 1 on the pinion. So moving from a 66 to a 69 = 1 tooth pinion, 69 to 72 = 1 tooth...
Dont have a 28? Do the match and figure out what Spur you need to match it. It is interchangeable.
Users browsing this forum: No User AvatarGoogle [Bot] and 4 guests
