I'm looking for an education in all things 'TECHI' but mainly the earlier motors. Any info out there on winds and different versions?
Cheers-Jason
The TAMIYA 'TECHNI' motor lot?
- Lonestar
- Has thanked: 623 times
- Been thanked: 171 times
Re: The TAMIYA 'TECHNI' motor lot?
voila for the data
http://www.zaonce.com/stuff/motors/motors.htm
Then some further historical and qualitative perspective here (google translation though, so good luck!)
http://tamiyablog.com/2008/01/tamiya-modified-motor-history-part-1/
Paul
Paul
- Bormac
- Has thanked: 20 times
- Been thanked: 11 times
Thanks Paul
TECHNIPOWER_ (SUPERSHOT)
Usable voltage: 6 - 8,4V
Torque at best efficiency: 315g-cm (7,2V)
R.P.M. at best efficiency: 20.300rpm (7,2V)
Current drain at best efficiency: 11,2A (7,2V)
Best efficiency: 79% (7,2V)
Turns:23 single
TECHNITUNED_
Torque at best efficiency: 290g-cm (7,2V)
R.P.M. at best efficiency: 17.200g-cm (7,2V)
Current drain at best efficiency: 9,2A (7,2V)
Best efficiency: 75% (7,2V)
Turns:27 single
TECHNIGOLD_ (BIGWIG, AVANTE, 959 & GR.B)
Usable voltage: 7,2V - 8,4V
Torque at best efficiency: 430g-cm (7,2V)
R.P.M. at best efficiency: 19.000rpm (7,2V)
Current drain at best efficiency: 14A (7,2V)
Best efficiency: 81% (7,2V)
Turns: 21 single - 0,8mm
Turns:23 single
TECHNITUNED_
Turns:27 single
- 2531 Views
Last post by FWLBP
- 2492 Views
Last post by Bormac
- 844 Views
Last post by purpletimbo
- 2277 Views
Last post by MelvinsArmy
- 826 Views
Last post by Jerzi
- 2425 Views
Last post by RC10th
- 2602 Views
Last post by tamiyadan
- 1255 Views
Last post by Sprocket
Users browsing this forum: Seznam [Bot] and 4 guests
