Tamiya #58148
Turbo
Tamiya #58148
Post by Turbo »
Tamiya #58148 Lola T94/00 Honda (F103-L) Runs and seems very fast. Body paint is flaking off and tires are pretty rough, but the rest seems mint and stock. Any tips for body paint removal?
mrlexan
Re: Tamiya #58148
Post by mrlexan »
I would go with the shodog method of Nitro fuel.
www.gojammedia.com
shodog
Been thanked: 91 times
Re: Tamiya #58148
Post by shodog »
since that paint is flaking already, nitro fuel would take it off really easily
Tadracket
Re: Tamiya #58148
Post by Tadracket »
Would 20% Top Fuel affect the lexan clarity??
He's an idiot. Comes from upbringing. His parents are probably idiots too.
shodog
Re: Tamiya #58148
Post by shodog »
Tadracket wrote:Would 20% Top Fuel affect the lexan clarity??
The fuel won't make it cloudy but if the paint did it's job in the first place then it will have etched into the p-lastic and once you strip it, it will look cloudy.
I found the higher the nitro content, the better it stripped.
Tadracket
Re: Tamiya #58148
Post by Tadracket »
I am getting ready to strip the TMS dually body and the paint is flaking so I don't think clouding will be an issue. Does not matter except for the glass area. I will be painting this body from the outside.
Turbo
Re: Tamiya #58148
Post by Turbo »
Didn't have any nitro laying around so I decided to try some orange cleaner we use at work, I had great results I think. Plus the house smelled like an orange grove for a day or two. :D And only used $2 worth of cleaner. Pics don't really do it justice. But paint is totally gone, body not cloudy or brittle, decals are unharmed. Karnak Karna-Klean.
templeofspeed
Been thanked: 33 times
Re: Tamiya #58148
Post by templeofspeed »
Nice that worked!!!! Name the brand of cleaner...the world wants to know!!! 8)
Turbo
Re: Tamiya #58148
Post by Turbo »
Karnak Karna-Klean asphalt & tar remover. Should be able to find it at larger home improvement stores. I use it to remove roofing and road tar from my truck and other equipment, along with the occasional ooops on vinyl siding, and haven't damaged my paint or the siding.
http://www.karnakcorp.com/pro_op_709.html
Turbo
Re: Tamiya #58148
Post by Turbo »
What I started with.
Return to “Tamiya Forum”
