RC500 - Help with part dimensions
- limestang
- Has thanked: 100 times
- Been thanked: 249 times
Hello, hoping to find someone willing to email close up photo's and dimensions of the following RC500 4wd parts:
Engine Pod #5520
Bulkhead Brace #5532
Alum Blocks for inner drive shafts #5542
Inner Wheel Hub #5537
Solid Axle #5560
I have been looking unsuccessfull on and off for over a year, but no luck. I am short some other parts (858, 2532, 2533, 5539, 6227), but the ones listed above appear to be something I could fabricate. I am by no means a master machinist, but I did stay at a Holiday Inn Express once (couldn't resist), and have a lathe and Mill that I've used to make some steam engines. Any help is greatly appreciated.
Thanks, Limestang
Engine Pod #5520
Solid Axle #5560
Thanks, Limestang
- a01butal
- Has thanked: 34 times
- Been thanked: 40 times
Re: RC500 - Help with part dimensions
limestang wrote:Hello, hoping to find someone willing to email close up photo's and dimensions of the following RC500 4wd parts:
Engine Pod #5520
Solid Axle #5560
Thanks, Limestang
Why do you want the #5560 solid rear axle? I know it's listed in the parts manual but I've never seen it used in an actual build and don't think there is a reference to it in the build manual.
This is all very interesting!
- a01butal
Well yah but now you need the diff and the rear dogbones and assorted other parts to complete the rear end drive.
- limestang
I have a complete RC500 2WD, and have been collecting the 4WD conversion parts. I have been using the following as a guide, but I'm not sure it is complete.
http://www.teamassociated.com/pdf/discontinued_items/cat_rc500.pdf
Pages 4 and 5 cover the 4wd parts.
Can anyone confirm whether or not this is complete?
Thanks Limestang
Thanks Limestang
- a01butal
Well that's pretty much it but you might try reading the 4wd instruction manual and view the pictures to kind of become famiiar with what parts go where.
- a01butal
Here you go: http://www.teamassociated.com/pdf/discontinued_items/5515_rc500-4wd-conv-kit-manual.pdf
- scootmike
- Has thanked: 8 times
Thanks a bunch, last time I was at Associated's site all the discontinued links were not working, I assumed they had deleted them from the site.
Thanks again!
Mike
Thanks again!
Mike
- a01butal
Part #2533 is the tie rod steel ball joint and it is the same as the RC10 shock rod end steel ball joint.limestang wrote:I have been looking unsuccessfull on and off for over a year, but no luck. I am short some other parts (858, 2532, 2533, 5539, 6227), but the ones listed above appear to be something I could fabricate. I am by no means a master machinist, but I did stay at a Holiday Inn Express once (couldn't resist), and have a lathe and Mill that I've used to make some steam engines. Any help is greatly appreciated.
Thanks, Limestang
http://www.ebay.com/itm/350607421351?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
I am trying to figure out the manufacturer of the tie rod plastic ends #2532 but haven't had any luck so far, I am sure it was from an outside source as the same part was used on Delta 1/8 cars.
- 1171 Views
Last post by FasterLouder
- 1667 Views
Last post by Jerzi
- 750 Views
Last post by BattleTrak
- 1401 Views
Last post by jfharper
- 648 Views
Last post by treehugger
- 1008 Views
Last post by Zipster
- 1031 Views
Last post by markbt73
- 602 Views
