Jammin' Jay's 6 Gear Rebuild
- rc10johnny
Hey Guys, anyone have a copy of Jammin' Jay's tranny rebuild? Mines in storage....somewhere.....Thanks Johnny
- Regular Member
- rc10johnny
Re: Jammin' Jay's 6 Gear Rebuild
Thanks Guys, now to print it off and on to two full bearing trannys
Edit; do you guys drill and set screw the 3/8X5/8 or glue??????
- Phin
- Has thanked: 87 times
- Been thanked: 248 times
Neither. I use Jammin Jay diff tubes with squared off drive rings.rc10johnny wrote:...Edit; do you guys drill and set screw the 3/8X5/8 or glue??????
- rc10johnny
- Phin
Ahh you mean on the outdrives? Thought you were talking about pinning the drive rings.
On one side the motor plate holds in the bearing but on the other side I didn't glue or use a screw. I thought the screw was only for when doing the bearing elimination mod since without the screw the outdrive had nothing holding it in. Since I eliminated the bearing inside the outdrive a little differently I didn't need the screw outside the case to hold in the 3/8x5/8.
- rc10johnny
- Regular Member
I haven't raced a 6 gear car in over 20 years, but I always used blue locktite to set the rings. Some other guys used CA glue. I always thought the set screws would unbalance the gear.
- 223 Replies
- 19671 Views
Last post by GreenBar0n
- 1945 Views
Last post by Russ Winn
- 2481 Views
Last post by JosephS
- 25 Replies
- 9583 Views
Last post by Dustydrone
- 1031 Views
Last post by Frankentruck
- 715 Views
Last post by integra22t
- 24 Replies
- 2654 Views
Last post by mikedealer
- 29 Replies
- 7187 Views
Last post by THEYTOOKMYTHUMB
