Help With Brazing Powdered Metal
LTO_Dave
Has thanked: 52 times
Been thanked: 287 times
Post by LTO_Dave »
Hey guys, I figured I'd ask here first to see if someone has experience before trying it for myself.
I stripped the bevel gear splines on both axles in my Tamiya crawler today, which are the first major parts I've destroyed in the entire time I've owned it. :mrgreen:
My question is whether or not I can braze the powdered metal gears to the steel axles, and will it hold up to abuse? I can pre-heat either of the parts if needed. I'm not sure what exact metal the powdered gears are made of and their melting point. Any help would be appreciated.
Re: Help With Brazing Powdered Metal
If they are both steel, shouldn't be a problem at all. I would preheat the powdered metal parts to help 'bleed' out any oils in the metal. Probably something like a silver solder would be great, although probably more expensive than the parts you are fixing, ie, not just regular old yellow brass rod with flux on it, but a silver brazing alloy.
Users browsing this forum: No User Avatar1911Colt and 8 guests
