6 gear outdrive problem
Hi all,
I am having a problem with one of my 6 gear's outdrives. I just installed new bearings, and now, whenever one of the outdrives gets pushed in a little, it stops spinning freely. If I pull it out a bit, it is fine. Could something be improperly assembled?
Thanks!
Thanks!
- Been thanked: 81 times
Re: 6 gear outdrive problem
Sounds to me like the c-clip has popped out and binding with the spline plate.
That would make sense, except I forgot to mention, I discovered the problem while the transmission was disassemed to install bearings. I made sure to check the c clip. Thanks, though.
I am thinking no one knows the answer. Or can it be everyone is in stealth mode these days?
- Has thanked: 1129 times
- Been thanked: 3917 times
How many bearings in each outdrive? If you can push and pull the outdrives it sounds like there is something missing
- 766 Views
Last post by Y'ernat Al
- 843 Views
Last post by afxman
- 858 Views
Last post by CamplinP
- 1025 Views
Last post by SpinningWheel
- 2972 Views
Last post by Asso_man!
- 1885 Views
Last post by 80sRunner
- 722 Views
Last post by upforit365
- 775 Views
Last post by RC104ever
