Steering bellcrank issue
Alright my rc10t has an issue the screw that holds the bellcrank is stripped out, is there an easy solution to this, the only fix I've seen is use rc10 steering in the front holes. I hate the sloppy steering it has right now with the little play in the bellcrank as it moves slightly.
Re: Steering bellcrank issue
so you mean the nose plate is loose also, the threads in the noseplate are stripped?
the only thing that would work for the stripped noseplate would be to use either a nut on the screw, on both, then put your bellcranks on, or find a ball bearing steering setup that sandwichesthe chassis with a shoulder nut to do the same thing.
if you just stick a nut under the bellcranks, you might have to adjust your ball ends to get rid of bumpsteer.
- 1396 Views
Last post by RC10th
- 1489 Views
- 5003 Views
- 736 Views
Last post by highwayracer
- 3191 Views
Last post by aip47-2008
- 2888 Views
Last post by jcwrks
- 1322 Views
Last post by escher
- 1181 Views
