Yokomo Worlds edition with "Yokomo Rough Track Kit"
Scott S.
Post by Scott S. »
This is my old Yokomo I got back after several years and it now is in rough shape but is now in progress of a rebuild....to a Pavidas replica. This is the only Rough Track kit I have ever seen..If anyone can get a part number for this kit I would like to know so I can search out another....also need the spring assembly for the upper deck. This car has the hardenend TCS system too. :)
* Team Associated * Reedy * LRP * Proline * Avid * Byrons Fuel * TFR *
Scott S.
Re: Yokomo Worlds edition with "Yokomo Rough Track Kit"
Post by Scott S. »
Rear tower..
Scott S.
Post by Scott S. »
Center car view.
Scott S.
Post by Scott S. »
last one.
Scott S.
Post by Scott S. »
one more.
littleVETTE
Has thanked: 6 times
Been thanked: 10 times
Post by littleVETTE »
did your center shock explode on you? you running stock diffs front and back?
Jirka
Has thanked: 33 times
Been thanked: 24 times
Post by Jirka »
You made me curious: What is the difference between rough track kit vs standard car?
Jirka
DerbyDan
Been thanked: 19 times
Post by DerbyDan »
Thats a fantastic buggy - rare too :D
Its great that you've got your old car back... looking at the pics, it would appear that a bit of graft & a good clean (& new top deck shock) will have it back to first class condition.
Jirka - I'm assuming that the 'rough track' refers to the 97 model kit that came with that centre shock/split top-deck?
http://www.tamiyaclub.com/showroom_model.asp?cid=80830
http://www.rc10talk.com/viewtopic.php?f=29&t=19503
@ Scott, thank you for sharing these pics with us, keep us posted with your progress on the project :wink:
Alex B
Has thanked: 23 times
Been thanked: 46 times
Post by Alex B »
Fantastic. I believe the rough track was a development of the WCS which was used to test parts at the Ranch Pit Stop worlds warm up in 97. The car had the longer Associated B2 shocks with complementary resigned towers, sprung upper chassis and redesigned rear camber link. Developments that ended up on the prototype MX 4 that Masami used to win the 97 Worlds.
:shock:
crusaderlyf
Post by crusaderlyf »
I ever saw once this rare yokomo buggy, used extra long shocks and the wing rising so high, the rear shock tower so different,using the prototype mx-4 wheels
a01butal
Has thanked: 34 times
Been thanked: 40 times
Post by a01butal »
This reminds me of bscotti's post from 2008 with those special parts:
http://www.rc10talk.com/viewtopic.php?f=29&t=6194
This is all very interesting!
Scott S.
Post by Scott S. »
littleVETTE wrote:did your center shock explode on you? you running stock diffs front and back?
This is how I got the car back, when i sold the car it was perfect. Thank God the bottom chassis is still in great shape. I just need to find a few parts.
Scott S.
Post by Scott S. »
Alex B wrote:Fantastic. I believe the rough track was a development of the WCS which was used to test parts at the Ranch Pit Stop worlds warm up in 97. The car had the longer Associated B2 shocks with complementary resigned towers, sprung upper chassis and redesigned rear camber link. Developments that ended up on the prototype MX 4 that Masami used to win the 97 Worlds.
True.
bscotti
Post by bscotti »
I ran one of my '97s at last year's VONats. Lots of fun until the upper deck shock shaft broke. I do believe the YR4/MX4 one will be a direct/close enough replacement.
Welcome aboard!
Classics rule, moderns drool
Scott S.
Post by Scott S. »
Thats what I suspect happened. then they threw the parrs away. :(
Do you happen to have the part number for the rough track kit?
Return to “Yokomo Forum”
