RC10 graphite from France
mk4
Post by mk4 »
this is a RC10 graphite , first run today and ....
restoration will continue
I hope i do not made mistakes !! i ' m not a spécialist .
Re: RC10 graphite from France
looks good! Just need to do a little trim in the steering.
adjust the middle bellcrank tie rod so the bellcranks are parallel the best you can.
then adjust the front wheels for a little bit of toe-in.
mk4
Post by mk4 »
ok , thanks for these instruction , i 'll make these adjustements and let you know how it run !!
Asso_man!
Has thanked: 40 times
Been thanked: 82 times
Post by Asso_man! »
Looks like there's crazy toe in in the rear too, adjust camber there as well so that the rear tires are parallel to the ground or slightly leaning inwards (negative camber). I would rather suggest a slight toe out on the front...
Come and visit the stable
mk4
Post by mk4 »
yes .... !! :oops: rear hubs come from a traxxas and they both are right side ... not good :mrgreen:
i've got a little packet today with spare parts ... right rear hub are inside :D
Users browsing this forum: No User AvatarDual and 17 guests
