YZ10?
- DennisM
- Has thanked: 30 times
- Been thanked: 62 times
Re: YZ10?
Thanks Alex - This model had no top deck from stock?Alex B wrote:Yes a YZ 10/870c. It has an after market rear shock mount and a peculiar (home made) half top deck and Kyosho gold shocks.
Gone fishing
Re: YZ10?
the 870c had the carbon fiber right angle backbone, which is installed in your car, no top plate. That half top plate looks like a place to put a servo, probably for a mechanical speed controller.
- Alex B
- Has thanked: 23 times
- Been thanked: 46 times
Re: YZ10?
I believe the 91' never came with a motor out of the box.DennisM wrote:Thanks for Your kind answers -
What about the motor - is it standard Yokomo stock for a 91´ works?
- DennisM
Re: YZ10?
Thanks again - but did Yokomo produce a motor labelled "pro" ?Alex B wrote:I believe the 91' never came with a motor out of the box.DennisM wrote:Thanks for Your kind answers -
Gone fishing
- Alex B
Re: YZ10?
Yes the last one is the Hotdog. The chassis, bulkheads, shock mounts and shocks are 1st generation YR4, the first Yokomo touring car. The suspension is that of a 91'. Interestingly the Hotdog came with rear dogbones and only 5 balls per diff. It also shared the same centre shaft and spur gear as the later YZ 10.
- DennisM
Re: YZ10?
Many thanks for the information - Is it still possible to source chassis parts for this one or the YR4?Alex B wrote:Yes the last one is the Hotdog. The chassis, bulkheads, shock mounts and shocks are 1st generation YR4, the first Yokomo touring car. The suspension is that of a 91'. Interestingly the Hotdog came with rear dogbones and only 5 balls per diff. It also shared the same centre shaft and spur gear as the later YZ 10.
I´have a new build YR4 without the top deck and that makes it flex just a little on the good side
Gone fishing
- Alex B
Re: YZ10?
http://www.fibre-lyte.co.uk/DennisM wrote:Many thanks for the information - Is it still possible to source chassis parts for this one or the YR4?Alex B wrote:Yes the last one is the Hotdog. The chassis, bulkheads, shock mounts and shocks are 1st generation YR4, the first Yokomo touring car. The suspension is that of a 91'. Interestingly the Hotdog came with rear dogbones and only 5 balls per diff. It also shared the same centre shaft and spur gear as the later YZ 10.
- 1702 Views
Last post by buttmonkey1969
- 5253 Views
Last post by Ronbo
- 1114 Views
Last post by Toaster
- 844 Views
Last post by bscotti
- 2266 Views
Last post by Mr. ED
- 975 Views
Last post by _timmy_
- 1115 Views
Last post by transamman908
- 22 Replies
- 3253 Views
Last post by Mr. ED
Amazon [Bot] and 3 guests
