Hogue RC10 trailing arm question
- nvxwax
Ok so i got a set of Houge trailing arms off eBay. Will they only work with a Houge chassis? can they be used on a AE graphite chassis?
Re: Hogue RC10 trailing arm question
They work best on a houge chassis but you can use small brackets to adapt to any graphite chassis. I ran them like that for years but my brackets made the wheelbase a little short. I can snap some pics if you'd like.
- nvxwax
That would be greatjwscab wrote:They work best on a houge chassis but you can use small brackets to adapt to any graphite chassis. I ran them like that for years but my brackets made the wheelbase a little short. I can snap some pics if you'd like.
OK, I had a trinity/composite craft chassis, not sure which. The last hole in the chassis on the outer edge I used to locate the small brackets. I then needed to drill two holes, so the arms are held on with three holes, the outer hold of the arm mount is just on the bracket. BUT, the wheel base was about .2" too small, with the arms level, I made the bones not quite parallel, and should have made them back a little. I'm not sure how much meat is on the back of the AE chassis, but if there is room to move it back, you should.
- nvxwax
Thanks,
I wonder if i can make a variation of the A&L brackets? I might use them for a runner for another VONATS option lol
that looks like the setup on one of my old trucks.
i do recall this truck was pretty fast 20 yrs ago.
was this meant for street use or what.
it does make it less wide witch makes it steer real well.
if i recall correctly.
i could be wrong i got to get this old truck going again.
check it out.
check it out.
- nvxwax
That looks like a A&L arm setup, just like the buggy i just built (Mine is fiberglass)
http://www.rc10talk.com/viewtopic.php?f=35&t=25574
- 717 Views
Last post by mikedealer
- 33 Replies
- 8110 Views
- 973 Views
Last post by THUNDERSTRIKE1
- 3321 Views
Last post by orangemazda
- 1173 Views
Last post by carloco8
- 94 Replies
- 11182 Views
Last post by GeneralZod
- 31 Replies
- 7136 Views
Last post by vintage AE
- 3802 Views
Last post by KidAgain
