Tamiya Bruiser
- lexus-5
- Been thanked: 11 times
Tamiya Bruiser
I'm new to Tamiya and was wondering. I purchased a Bruiser off CraigsList. I'm In the process of tearing it down slowly and cleaning. I was messing with the front suspension with the servo rod on the linkage attached and it seems the front wheels almost click into position when I pull the long servo rod back and fourth. Is that normal? Also it is VERY hard to turn the hubs left and right like somethings binding, but I can't see any interference with the steering link rod. Is the stiffness in the left to right motion of the front steering normal for a Bruiser?...or Houston we have a problem...??
Remember it's either a runner or a shelfer. Everything else is just parts.
Check out my Gallery for more Collection Pictures http://www.rc10talk.com/viewtopic.php?f=77&t=20697
- Been thanked: 4 times
Re: Tamiya Bruiser
Your nuts to tight lol wheel nuts or screws holding hubs?OR old dried up grease in hubs? DON
- lexus-5
Re: Tamiya Bruiser
Ok Don Thanks I'll check it out. I haven't touched or adjusted anything on the truck so it's NOT MY FAULT !
Thanks for the reply.
- shodog
- Has thanked: 3 times
- Been thanked: 91 times
Re: Tamiya Bruiser
I'd take it all apart. There could be several things causing what you describe. The front hubs have pins that give it a crude one way. These get dry and need to be rebuilt anyway. At worse your axle is broken
- lexus-5
Re: Tamiya Bruiser
Thanks for the input and I did take the ends off the front differential and a piece of the casting on one side is cracked and fell into my hand. I will be looking for a replacement front diff assy and I will also open and check the "guts" for damage. Thanks again and I am assuming that assembly should move/turn back and fourth with no binding and should be smooth if there are no issues.
- 2014 Views
Last post by vintage racer
- 2985 Views
Last post by tuna.Rc
- 351 Views
Last post by Dustydrone
- 1001 Views
Last post by TRX-1-3
- 2765 Views
Last post by clhuke64
- 2252 Views
Last post by XLR8
- 41 Replies
- 7102 Views
Last post by DennisM
- 1842 Views
Last post by Erich Reichert
